SOHC VTEC cam lobe and follower wear pic
Old 11-24-2001, 09:58 PM
CivicFerio's Avatar
Default SOHC VTEC cam lobe and follower wear pic
My D16Y8 has a worn out VTEC cam lobe and a follower. The cam has worn down to the softer metal core and also wore a 1mm deep groove on the follower. And it only occurred on the last vtec lobe closest to the distributor (passenger side).
Since my front driver side wheel bearing has gone bad after 85K miles of street and hard track usage. I think the cam might have gone dry because of the long right hand turn sweepers. What's your opinion on this? Has anyone has this problem before??? I always top off my oil after every track session. Thanks
Charleston
Old 11-24-2001, 10:47 PM
paulzy's Avatar
Default Re: SOHC VTEC cam lobe and follower wear pic (CivicFerio)
all I know is that those things are bitch to put back together when they're all apart...
Old 11-25-2001, 06:30 AM
DragII's Avatar
Default Re: SOHC VTEC cam lobe and follower wear pic (Slow_ass_4dr)
Ouch, what are your mods?
Old 11-25-2001, 08:27 AM
Frosty_spl's Avatar
Default Re: SOHC VTEC cam lobe and follower wear pic (DragIIcivic)
were your valves adjusted properly?
Old 11-25-2001, 12:51 PM
CivicFerio's Avatar
Default Re: SOHC VTEC cam lobe and follower wear pic (Frosty_siR)
My mods are DC sport 4-1 header and 5Zigen muffler...
Plus I always adjust my valve clearance every 15K...
[Modified by CivicFerio, 9:53 PM 11/25/2001]
Old 11-25-2001, 03:17 PM
DragII's Avatar
wierd...those things don't usually just wear out like that. I would have to guess something was out of alignment.
Old 11-25-2001, 04:51 PM
New User
Raymund's Avatar
If only one cam and rocker-follower is severly worn out, you should check the spring rates on all your intake vavles. It might be an out of spec/overly stiff vavle spring on that particular one.
Old 11-26-2001, 03:09 AM
D Tranny Guru
Mista Bone's Avatar
I must ask what kinda of track useage and what were the mods? Only way your gonna starve the cam of oil is with some nice road race slicks. Unless you drive 2 minutes one way on a skid pad!
Old 11-26-2001, 06:41 PM
CivicFerio's Avatar
Default Re: SOHC VTEC cam lobe and follower wear pic (Mista Bone)
I took my car to the track after it was 3 months old.. And attend 6-7 track events each year for 3 years. My car's engine is fairly stock and yes I drove on slicks..
Charleston
b20turbojason
12-26-2003 10:22 PM
cr-x si
08-03-2002 08:43 PM
CivicFerio
14
11-30-2001 11:50 AM
CivicFerio
11-26-2001 09:16 AM
Quick Reply: SOHC VTEC cam lobe and follower wear pic
