SOHC Cam Question
I traded a exhaust I had for a edelbrock sohc cam gear. But I have no idea what year its for . Is there any way I could find out what year of car its for?
Re: SOHC Cam Question (Rocks)
Here's a pic if that would help http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg
Modified by Rocks at 10:30 AM 8/2/2004 |
all sohc civic (88-2000) camgears are the same.
Re: SOHC Cam Question (peiku)
anybody else with any info. I want to assure the dood im selling it to that it works fine.
does it have a part number stamped onto it? if so, you can try searching their website for that number and see what comes back?
Re: SOHC Cam Question (TouringAccord)
nope it does not . The edelbrock website has two part numbers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peiku »</TD></TR><TR><TD CLASS="quote">all sohc civic (88-2000) camgears are the same.</TD></TR></TABLE>
WRONG, the ek's i believe have 40 tooth gears while the egs have 39 teeth |
Re: SOHC Cam Question (Soccerking3000)
Re: SOHC Cam Question (DewMota)
they are the same gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">
WRONG, the ek's i believe have 40 tooth gears while the egs have 39 teeth</TD></TR></TABLE> i'd put $10 on that being untrue |
Re: SOHC Cam Question (soccaian)
IM thinking this is for 96-00 sohc's due to the realtion of the keylocation compared to the tdc marks.
Re: SOHC Cam Question (civic-4-ges)
the y8 and the z6 cams are diffrent! they are off by like one thooth i belie!ve
Re: SOHC Cam Question (zeroracerh)
If it is a SOHC cam gear, with the round holes its a 88-95 cam gear. If it was a 96-00 it would be slotted like this one
https://www.edelbrock.com/automotive...ain/gears2.jpg |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peiku »</TD></TR><TR><TD CLASS="quote">all sohc civic (88-2000) camgears are the same.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">
WRONG, the ek's i believe have 40 tooth gears while the egs have 39 teeth</TD></TR></TABLE> I'd go with PEIKU he's right, cam gear all fit 88-2000 civic, Soccerking your wrong because its only the CAMSHAFT that makes it off a tooth when u install a D16Y8 96+ cam into a 92-95 Civic motor thats what makes it different |
Re: SOHC Cam Question (dramatic_scientist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dramatic_scientist »</TD></TR><TR><TD CLASS="quote">I'd go with PEIKU he's right, cam gear all fit 88-2000 civic, Soccerking your wrong because its only the CAMSHAFT that makes it off a tooth when u install a D16Y8 96+ cam into a 92-95 Civic motor thats what makes it different</TD></TR></TABLE>
Well, while a cam gear might FIT all 88-00 civic's, the 96-00 cam key sits in a different position than the 88-95 cam gear. Its timed 3.7 degrees differently. So technically, no, they are not the same. |
Re: SOHC Cam Question (Marauder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">its timed 3.7 degrees differently.
So technically, no, they are not the same.</TD></TR></TABLE> Couldn't agree more |
Well, while a cam gear might FIT all 88-00 civic's, the 96-00 cam key sits in a different position than the 88-95 cam gear. Its timed 3.7 degrees differently. So technically, no, they are not the same.</TD></TR></TABLE> Exactly...I have a Z6 cam and cam gear in my Y8...there are quite a few topics on this if you want to know more. |
i have read that for the y8,
the only gear that is truly accurate is the aem gear. which would be a fact that would lead one to believe that NOT all sohc gears are the same. |
Re: (Tad)
i thought that the Timing belts were different also.
Re: (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">i thought that the Timing belts were different also.</TD></TR></TABLE>
they are, there are many different timing belts, different lengths. doesnt neccessarily mean the gears will be diff. but the belts are diff true |
Re: (Tad)
the z6 and y8 are in fact slightly different and require approxamitely 5 degrees of advanced/retarded timing
Re: (Art In Motion)
we couldn't figure out why my timeing was off cause i had a 96 head on a 92 block with an aem cam gear so we had to advance the timeing
you should be fine |
Re: (NLR808)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NLR808 »</TD></TR><TR><TD CLASS="quote">you should be fine</TD></TR></TABLE>
LOL....Fine??? How should he be fine? Did you read the first post in this thread? |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">If it is a SOHC cam gear, with the round holes its a 88-95 cam gear. If it was a 96-00 it would be slotted like this one
https://www.edelbrock.com/automotive...ain/gears2.jpg</TD></TR></TABLE> This is true I called edelbrock and they told me the same thing. Thanks for the help. |
