sockets question
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">6, so there is grip on the corners and the sides
if you use 12, and its siezed, you'll just round it off</TD></TR></TABLE>
True story, then youll need to bust out with one of these bad boys.
(btw i own that same kit and it never let me down in time of need)
Re: (Luserkid)
I use the sears craftsman ones and the smaller ones are f'd up already. Lifetime warranty baby.
For the screw extracters I have a snap-on set
Re: (1jdmferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1jdmferio »</TD></TR><TR><TD CLASS="quote">those turbo sockets come in handy for things like when the 14mm bolt for the timing belt tensioner strips out </TD></TR></TABLE>
Thats too funny. That is the last time I used mine about 3 weeks ago. LOL!
Re: (excivicboy96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 »</TD></TR><TR><TD CLASS="quote">i always wondered what the point was for 12pt sockets?</TD></TR></TABLE> The 12mm 12pt is what you HAVE to use to take the drive shaft out of most fords. The bolt will only fit a 12pt.
Re: (excivicboy96)
A lot of bolts are 12pt head...and if the bolt is a 12pt head the wrench to take it off is also the same size as the bolt FYI
Re: (PhatAcuraIntegra)
clutch and flywheel bolts on our hondas are 12 pt sockets as well
but yeah, as stated 6 point sockets are better on a 6 point bolt. obviously
Re: (excivicboy96)
They're easier to get onto the bolt/nut, since it'll fit every 30 degress instead of every 60. Isn't a very big deal unless you're working with a breaker bar in limited space.
Re: (fdavie)
I would consider that a bigger advantage of the type of ratchet that your using and the degree of swing...you can almost always reach down and twist the socket to fit on
