So wheres the ECU hidden on Del Sols?
hey, im finishing up a swap from non VTEC over to VTEC so i need to change ECU's where is my ECU and how would i remove it and install the b16a ECU? is there sottering required or what, thanks in advaNce.
1 Post
Re: So wheres the ECU hidden on Del Sols? (SiKDeLSoL)
is it not behind the passengers kick panel? also there are wiring harnesses that plug into the ecu so you shouldnt have to solder anything as long as you dont rip wires out.
Re: So wheres the ECU hidden on Del Sols? (monicle)
so you can do an engine swap but you dont know where the ecu is? right man and its soldernot sotter
Re: So wheres the ECU hidden on Del Sols? (akumaracer)
It's on the passenger side under the carpet - right where you'd expect a set of kick panels for a component set.
mita
08-28-2014 11:46 PM
