Smoke..
Old 04-20-2007, 04:49 PM
Boostedb20EH2's Avatar
Default Smoke..
Every since i replaced the synchro on my tranny there has been a bit off smoke that burns off when i am idle(from under the hood). Actually quite a bit. I really cant figure it out, I thought it could be oil burning off the block (i had tranny fluid and oil get all over my block because of a slight valve cover grommet oil leak i just replaced) But i just degreased the whole bay tonight. The weird thing is i check my oil twice a day..and it does not go down. And there is coolant in the reservoir. I cant figure out what is causing this
Old 04-20-2007, 06:01 PM
Default Re: Smoke.. (Boostedb20EH2)
15 views and not one answer. Amazing.
Old 04-20-2007, 06:02 PM
97Ej6mike's Avatar
Thats the most likely diagnosis, being you spilled trasn fluid all over the block.
Make sure you bolt the VSS back in tightly, if it still smokes, it almost sounds like it could be leaking from there, down onto your exhaust pipe, causing it to come up as smoke.
As for thinking it may be coolant, dont be fooled into thinking that just because there is coolant in the reservoir that your not leaking any. I have had this problem TWICE before. It may be a slow leak, and it doenst take a whole lot of coolant, if leaking directly over the exhaust ( Around the IAC area) to make noticable amounts of steam/smoke come up from under the hood.
Also, if the reservoir is full, that doesnt necesarily mean that its all ok, for some reason when this happened to me my reservoir wasnt filling up the radiator, even tho it was draining rapidly from a broken hose ( i was in my garage, finding the leak by letting the motor run)
Old 04-20-2007, 06:11 PM
Default Re: (97Ej6mike)
Some help Thanks man. Ill take a look tomorrow,any other opinions?
Old 04-20-2007, 06:13 PM
97Ej6mike's Avatar
The only way to find out what it really is, is to drive it around the block, warm it up a bit, bring it home, pop the hood, and get busy lookin to see what it could be.
Old 04-20-2007, 06:17 PM
I forgot to add this only happens at normal operating temp. (obviously)
Old 04-20-2007, 07:58 PM
Mandark06's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostedb20EH2 &raquo;</TD></TR><TR><TD CLASS="quote">15 views and not one answer. Amazing.</TD></TR></TABLE>
it's because it's 4/20 and your topic title is "smoke"
like me for instance, i didn't even read any of the posts, i just clicked in and read the first few words to see what it was about and then left = )
Old 04-20-2007, 08:01 PM
Default Re: Smoke.. (Mandark06)
Ha,what a stupid excuse for a "holiday". Most people i know who smoke, do it on a daily basis,so i dont see how today is special for them.
Old 04-21-2007, 11:25 AM
I forgot to add that i park in my garage every night and there is not a drop of any fluid on the cement.
Old 04-21-2007, 01:22 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostedb20EH2 &raquo;</TD></TR><TR><TD CLASS="quote">I forgot to add that i park in my garage every night and there is not a drop of any fluid on the cement.</TD></TR></TABLE>
hmm, that is pretty strange.
93grayeg
10-24-2009 09:29 PM
92ehatch
18
12-18-2006 09:59 AM
blumpfish
06-18-2006 09:23 PM
b18c5T
01-31-2004 09:44 PM
TEXN3
01-24-2004 04:33 PM
Quick Reply: Smoke..
