smog failure, install new cat and got worse need expert analysis
Ok guys here's the story, I got a notice in the mail for a smog check being due so i went out to get one. Well the first smog check I didn't do anything to the car prior to the smog, i just drove it around town and kept the rpms at around 3-4 rpms then got it smogged. I failed the smog and the smog guy told me to get new spark plugs and a new cat and it should pass.
First smog test report
I went to a muffler shop and had them install a new cat for me and i installed new ngk spark plugs on the car, i even installed a new pcv valve and cleaned out my air filter. I went back to the place today to have it smogged, feeling very nervous. But I failed again, this time i failed even worse to gross polluter. The smog test guy was really confused, he didn't know what to tell me other than to take it to a shop to have it analyzed and repaired. He had no idea why it got worse and so did i. Prior to the smog test I drove around town at about the same 3-4 rpms like i did in the first test.
Second smog test report
My mods include dc sporst 4-1 header, new high flow cat, tsudo piping catback with apexi worldsport 2 muffler, and an aem short ram intake with a clean filter.
What do u guys think is the problem?
Re: smog failure, install new cat and got worse need expert analysis (SkyeC)
The exhaust manifold should have nothing to do with it. I'd find an ebay cat or a cat off of someone in the forum's car.
throw in a stock intake, stock header and a stock exhaust then it should be fine. I wouldnt smog my car with those aftermarket parts even if it is CARB legal.
Re: (db8gsr_teg)
so if i put on my stock manifold i should be able to pass with flying colors?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scuzz »</TD></TR><TR><TD CLASS="quote">The exhaust manifold should have nothing to do with it. I'd find an ebay cat or a cat off of someone in the forum's car.</TD></TR></TABLE>
isn't an ebay cat just a test pipe therefore instant failure.
i have a brand new high flow cat, my friend got one for his crx same one as i got and passed with extremely low figures.
Re: (byronl)
listen get a oem cat not no hi-flo cheapo
a free flowing exhaust helps wen it comes to testing
makes sure your timing is good
and beat the **** out of it before you get it tested dont baby it
Re: (db8gsr_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8gsr_teg »</TD></TR><TR><TD CLASS="quote">throw in a stock intake, stock header and a stock exhaust then it should be fine. I wouldnt smog my car with those aftermarket parts even if it is CARB legal. </TD></TR></TABLE>
Why he passed the visual?
And those parts are not super extreme anyways
Re: (packthis)
Why would you drive around town with 3000-4000 rpm revs only??? Cats work better with heat, don't hold back on the revs!
I would say the cat the muffler shop sold you is a peice of $hit! NO should not go up like that with a NEW cat. They screwed you IMHO. Buy a used OEM cat off of someone here and I bet it'll run a lot cleaner.
Re: (packthis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by packthis »</TD></TR><TR><TD CLASS="quote">
And those parts are not super extreme anyways</TD></TR></TABLE>
Cause all those parts are CARB exempt and it will pass visual. But sometimes they make you fail and sometime they make you pass. Its simple like that
Re: (db8gsr_teg)
Cause all those parts are CARB exempt and it will pass visual. But sometimes they make you fail and sometime they make you pass. Its simple like that </TD></TR></TABLE>
if anything the intake and free flowing exhaust will aid the engine and possible lean it out a bit , aftermarket intake and exhaust will not hurt the emmisions performance of a vehicle at all.
and whom ever said throw the stock mani and exhuast on and it will pass abovious doesnt now anything
the readings indicate there is a big problem, most likly the cat is not up to par, timing might be off, has nothing to do with his header or intake
Re: (jdmchop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmchop »</TD></TR><TR><TD CLASS="quote">
the readings indicate there is a big problem, most likly the cat is not up to par, timing might be off, has nothing to do with his header or intake </TD></TR></TABLE>
i feel dumb even asking,
but if there's after market headers and crap out there that dont have a carb legal crap on them, then why i read else where that they do make a difference when time for smog comes...
in other words, these parts dont don't effect smog????
anyone every pass with the usual I/H/E..i know i never did
Re: (EvilPinkEye)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvilPinkEye »</TD></TR><TR><TD CLASS="quote">i feel dumb even asking,
anyone every pass with the usual I/H/E..i know i never did </TD></TR></TABLE>
They could potentially effect smog, however 99% of them don't. The reason some of them don't have the CARB EO#s is because of the application fee. It's something like $5,000 a EO# and for some companies, being legal in 49 of the 50 states leaves a large enough market to not care.
How large is this new cat? Seems like the 15mph is too slow to keep it hot.
Re: (EvilPinkEye)
thx for all ur replies guys, i think ur right about me going at 3-4 rpms. Because I took I took it to my dad's friends mechanic and without telling me, he took the car for a drive, went to a smog test only and came back and it passed with flying colors! Lemme show u guys the results. I asked him what he did but he just smiled at me and said 'mickey mouse' iono what that means but i kinda have a guess haha.
here's the final smog results
Re: (byronl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by byronl »</TD></TR><TR><TD CLASS="quote">thx for all ur replies guys, i think ur right about me going at 3-4 rpms. Because I took I took it to my dad's friends mechanic and without telling me, he took the car for a drive, went to a smog test only and came back and it passed with flying colors! Lemme show u guys the results. I asked him what he did but he just smiled at me and said 'mickey mouse' iono what that means but i kinda have a guess haha.
That sounds like you got a smog "hookup"
Re: (Ghetto Civic HX)
for future reference, i found out why my readings were all weird. It wasn't because of my cat, it was because of my o2 sensor. I had used a bosch o2 sensor and that's why i failed, it was new too. I just bought a new oem denso o2 sensor and passed again with flying colors.
Re: smog failure, install new cat and got worse need expert analysis (Dude29662)
Seeing all that I am glad I live in a state were there is visual and a gas cap check. maybe some year they will get around to sniffer testing the tail pipe. but buy then my car will be outside the test range
Re: smog failure, install new cat and got worse need expert analysis (instructor74)
SEAFOAM
Winger - Winger (1988) - 03 - Seventeen.mp3 [64Kbps] (04:05)
Re: (VTcivicHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTcivicHB »</TD></TR><TR><TD CLASS="quote">I like how on the second sheet instead saying "Fail" it says "Gross Polluter"</TD></TR></TABLE>
Yeah, I chuckled a little to myself when I read that.
La Zona Imagery
05-23-2016 11:05 PM
dragonkx
03-13-2012 06:18 AM
boots420
37
05-18-2007 03:35 PM
careawholelot
02-06-2003 12:09 PM
