Sluggish d16 issue
Sluggish d16 issue
whats the most common problems to make a d16z6 feel like its always hill climbing at low rpms? TDC is good? what else can it be? or what sensors would be a huge factor?..need help asap
Re: (coupej1)
please be a lil more specific..... have you done a fuel press. and volume test? checked for a clogged cat. conv.?? i.. have you looked at the integrity of the secondary ignition on an oscilloscope??? when the car is cold , hot.... details my friend ,, details
Re: (wrenchez81)
also check and make sure the timing marks are dead on!! having retarded cam timing will have the same symptom!! has the cyl head been milled or "cut"??....
Re: (jdmkid_82)
it idles ok, but when i somewhat feather the gas and let go rpms drop really low to the point it wants to die out..the car will suck alot of air but just lacking that power
Re: (97_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97_coupe »</TD></TR><TR><TD CLASS="quote">What injectors are you using?</TD></TR></TABLE>
Re: (iamthefollower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iamthefollower »</TD></TR><TR><TD CLASS="quote">Are their any vaccums undone??</TD></TR></TABLE>
ive got all vaccums checked and re-checked
Re: (morningstar)
but seriously it sounds like you just have the IAT and MAP sensor connections swapped...its a common mistake....I'll be over in the morning to take a look though
