sLUGGish B16 Del Sol ?!
I've got a 94 Del Sol B16 (all factory) 150k miles.....
I have new plugs, wires, cap, rotor, ign Module, ignitor, fuel filter, timing belt, v-tech seal.
I also have put on a CAI kit.
It runs pretty good with A/c off or at full throttle, but a little sluggish at mild throttle, or at cruising speed.
When it is cold, it's real sluggish.....it kinda has a bad hesitation, and it seems to be worst while i'm cornering while cold too ( but maybe i'm trippin on that part). It is nearly unbarable at times if cold engine and A/C on.
yet...I still get 28 mpg avg.....huh....
What do yall think it is ?
Re: sLUGGish B16 Del Sol ?! (sidesi)
my car feels the same way in the summer months with the ac on (00si B16). i found that if i run the stock intake it is a lot more responsive in the low end with ac on..
Re: sLUGGish B16 Del Sol ?! (ApolloSpeed)
I had the same sluggishness with my jdm b16. It was also bogging at low rpm's (2k - 3k) I changed my ignitor and this fixed the problem. Do you have a brand new distributor?
Re: (Falqon)
ignitor is new and cap and rotor and coil......but not whole distributor....
I'll double check timing....
not sure about O2 sensor (how do I check that) ?
i'm not throwing any codes also.
Re: (Falqon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Falqon »</TD></TR><TR><TD CLASS="quote">like I asked, timing?</TD></TR></TABLE>
Re: (young noob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by young noob »</TD></TR><TR><TD CLASS="quote">
????????????????????????</TD></TR></TABLE>
It's the number of degree's before the piston reaches top dead center when the spark plug ignites the fuel inside the combustion chamber.
Re: (Falqon)
It's the number of degree's before the piston reaches top dead center when the spark plug ignites the fuel inside the combustion chamber.</TD></TR></TABLE>
i know what timing is, i was just saying that that guy hasnt checked out the timing of the car yet
