Slow GSR, didn't think this was possible
Honestly i don't know what is going on, i was at the track the other day and ran a 16.2! are you kidding, a 16.2 in a JDM GSR. I own a 2000 Honda Civic Si, a B18C with the stock B16 trans, race mounts, AEM Hybrid Intake, stock SI exhaust and stock GSR exhaust manifold. My question is the car runs fine, no check engine lights, vtec light shows vtec is engaging, new tires running 30 psi all around, full skunk 2 suspension, i launched at 4000 rpm yes it did wheel hop pretty bad right away but i thought the launch wasn't too bad, how is this possible? (Shifts were at about 8200) also i was at about 8000 rpm when i crossed the line in 3rd gear which also doenst make sense but i shifted into 4th to start to slow down. Sooo not too sure why a motor that across the internet consistently runs low 15's high 14's stock and even lower sometimes depending on application, how i managed to run a 16.2!
Re: Slow GSR, didn't think this was possible
Live in wisconsin, stock Jdm P72 ecu, no tune. Another guy with a 2000 civic SI with his stock B16A2 (i.h.e.) ran a 15.6 No GSR should ever get crapped on by a stock B16 lol i talked to him later he said he just wanted to see where his car was at before his build.
wheres your timeslip?
Cuz according to you the car is running great... So the only thing that could be the problem is YOU...
And he'd be wasting his money if he got a tune on a stock car with an intake...
His driver mod needs recalibrating...
my buddy nick had the same problem with his del sol the jdm ecu was tuned for 100 octane gas and the compression of a jdm motor, he got a p28 with hondata and the car was night and day!!!
Believe me lol its not the driver i will admit im not a pro drag racer but im on key most of the time, it just doenst seem to have the same power as my obd1 jdm gsr i used to have in my hatch (before it was stolen) but idk im gonna have to figure something out, and as far as the car running great i haven't had it on a dyno to confirm specs but clutch is new as of last year, recently did a full tune up (plugs, wires, cap, rotor, fuel filter) So you think 4k is too high for a launch? I was at 2K the first pass just to see how sticky the track was that day and bogged down HORRIBLE so i upped it to 4k so idk. There will always be next year more money to invest in my baby.
i was going to look into a hondata system first i will be needing to try and pass emissions im trying to get my hands on a OBD2 USDM GSR ECU to i can try and convert the JDM engine to USDM so i can pass emissions(will be posting that soon) but ya thanks for that recommendation i will defiantly be taking it into consideration
im from wisconsin originaly and have done alot with bee over there, call him he might even have a usdm ecu for you.
just because your car is suppose to run a cetain time does not mean its going to run that time, i usally run high 10's low 11's with my gsr turbo but on some days ill run 14s because the traction on the track is ****
I'm not Rick!
yeah did you have the same tires as that ninja with the b16?
do you have the same tranny as him? what about your wheel size?
they play big roles
they play big roles
318 Curves, 11 miles
I've run 16.2s in my gsr'ed 00 EX with B16 transmission, which is almost the same car as you. 2.4 60ft sounds about right for that time to me. That's exactly what I was running last season. And mine felt really fast from a roll, but the 1/4 mile times sucked.
How much wheel hop are you getting? Are you running all the correct engine mounts? Might want to check torque mounts - mine launches dramatically better after I fixed them. How's the suspension? Mine also launches dramatically better after I replaced worn out stock shocks.
Take care of your wheel hop problem and I think your times will go down by almost a second.
16's doesn't sound that far off in a full weight EM1. Really it doesn't.
But I'm wondering if you don't have automatic cams in that beast? (from a car with an auto tranny I mean)
Are those internet times for the same chassis as yours? How many times did you run the car on the track?
Thanks guys ya I did have some wheel hop right away, and I have a new skunk2 coilover suspension, I'm running inovative race mounts no torque mounts just the three, I'm running with new eagle gt's 195/55r15 the other SI was running same 15' rims my guy also had his 94 civic coupe there with gsr, stock everything on the car minus skunk2 manifold and 4500 rpm launch control he ran a nice 14.6 but anyway I guess I need to get tuning invest in an ECU and do some upgrades thanks for all the imput
The 3M polyurethane is great, but it's about $30/tube, and you'll use most of a tube on 2 mounts. Still cheaper than aftermarket poly mounts. They sell polyurethane driveway sealer at home depot that is MUCH cheaper, and IMO works just as well. I've used them both, and other than the driveway poly being gray instead of black, I can tell no difference in the application or functionality.
Oh, and get disposable rubber gloves. That stuff sticks to your hands like crazy, and you really need to use your fingers to fill all of the gaps up with poly.
NB4 flames for ghetto DIY poly mounts. What can I say, they're cheap and they work.
and i am not running on torque mounts i have the inovative race mounts which only use 3 primary solid race mounts, as i see i suppose its an average time i really am disapointed that its running those time and i have a friend in a eg coupe running 14's with only a skunk2 manifold and launch control... well i guess i just had high expectations from what i was hearing from everyone with stock integra's and gsr's in other cars. Well if i want to run those times im gonna have to invest more in my 300k mile blue sheep
Umm 16s is way off considering he should be able to hit a low 15 with the stock b16... With a GSR it should only be faster... Across the board...
the jdm ecu might be tuned for a higher octane.what gas did you use? also next time remove the spare and back seats and clean the car out.
this is your problem, with your setup your gona need a perfect launch to run low 15s and a 2.4 60' is not going to cut it. My first time at the track about 12 years ago I ran a 17.2 in my gsr with I/H/E about 10 passes later that night I was in the mid 15's. Everyone thinks there a bad *** driver but the clock with put you in your place real quick.
