Slight Misfires on B16
I've never been able to find out why my B16 del sol misfires.
It is very slight........I can see it happening on the timing gun.
At idle, It misses probably 1 or 2 times per couple seconds on random cylinders.
I've changed all filters, seafoamed, new plugs and wires, new battery, new ignitor, new cap and rotor, good timing,.....
I just don't know what else to try! Maybe try cleaning injectors ?
If so, how do I take them out and what do I do to them.....
Any other suggestions.
Re: Slight Misfires on B16 (ApolloSpeed)
Have you checked the compression of all of the cylinders? To get the injectors out, just unbolt the fuel rail, undo the fuel lines and pull it out, you might need new o-rings though if you take them out because they may not seal when you put them back in.
