Slave Cylinder question
Old 09-09-2005, 11:56 PM
hmtcrxsir's Avatar
Default Slave Cylinder question
Is it possible that the Slave Cylinder is bad and the SC is not going back in when the clutch pedal is all the way up? Whenever i drive my 95 Civic it feels like i the clutch is not engaging all the way. It doesnt feel like the clutch is slipping. It just feels like you are driving the car with the clutch press. Help?
Old 09-10-2005, 12:03 AM
HondaFanatic708's Avatar
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: Slave Cylinder question (hmtcrxsir)
Could be slide the boot out of the way and check it for movement if you think thats the case.
Old 09-10-2005, 12:13 AM
hmtcrxsir's Avatar
Default Re: Slave Cylinder question (HondaFanatic708)
the whole bar popped out in the SC. It sperated from the SC. So i had to push it back in. Is the little bar in the SC be able to come all the way out like that? Did i mess something up?
Old 09-11-2005, 01:10 AM
hmtcrxsir's Avatar
help?
Old 09-11-2005, 04:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir &raquo;</TD></TR><TR><TD CLASS="quote">the whole bar popped out in the SC. It sperated from the SC. So i had to push it back in. Is the little bar in the SC be able to come all the way out like that? Did i mess something up?
</TD></TR></TABLE>The piston in the slave cylinder should not be like that. Pushing it back in will not fix the SC. Once that seal is broken it wont hold pressure anymore. You will need to replace the slave cylinder and bleed the system. If you haven't dropped a B-series in the car, a slave cyl for the 95 civic has a list price of $72.01 but you should be able to get it for like $55-$60 from your local dealer. If not check out http://www.hondapartsdeals.com. Oh and the Honda part number is 46930-SR3-013
I bet if you replace the SC it will eliminate your problems.. Good luck!!
Osbjoey
04-14-2013 08:48 AM
SiRCiviC94
08-02-2012 04:41 PM
NeWnMpR0VeD
06-17-2006 11:46 AM
anewfoundkevin
04-20-2004 03:41 PM
Quick Reply: Slave Cylinder question
