Skunk2 IM
Skunk2 IM
I've looked and Can't find anything on how to install one in my 92 Civic with a D16Z6. If anyone knows where I can find one or has done one how easy are they?
Also I will be doing a write up if there isn't one
incredibly easy. disconnect vacume hoses label what goes where using masking tape and a sharpie. unhook throttle cable and anything attached to the im. buy new im gasket and throttle body gasket. remove the 8 nuts holding the im to the head. make sure there is nothing left behind from the old gasket, put the new one on put on the new im tighten it down replace the vacume lines put all the parts you took off the factory im and put them on the new im hook up the throttle cable (needle nose pliers help).
Reap the benefits or your new im!!
Banned
Took me roughly 3 hours to install mine on my y8, I was taking my time and had a few friends over. I ordered the hondata IM gasket with it so everything went good. I think the most trouble i had was the IM support bracket that is held on with with two bolts was a little difficult to get to. But other than that everything was pretty much straight forward. Works well and deff. worth all the effort in the end.
Re: (dynimitejack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynimitejack »</TD></TR><TR><TD CLASS="quote">np. how much did you pay for the im? are you planning to turbo?</TD></TR></TABLE>
100 Dollars lol
100 Dollars lol
morphvsmeth
05-29-2011 06:09 PM
