Skunk2 Camber Kit...will I have clearance problems?
Old 03-10-2003, 09:02 AM
FBP Si 2000's Avatar
Default Skunk2 Camber Kit...will I have clearance problems?
Hello...I'm interested in getting the Skunk2 camber kit...the ones that replaces the whole arm, but I'm not sure if I'll have clearance problems. I've heard that the arm could hit the fender/shock tower if the car is too low. Here are pictures of how my car is sitting right now...
Think I will have clearance problems? Sorry if you can't really tell by the pictures...
Thanks in advance.
Old 03-10-2003, 09:08 AM
Stryker908's Avatar
Default Re: Skunk2 Camber Kit...will I have clearance problems? (FBP Si 2000)
::Bump:: I would like to know also
Old 03-10-2003, 09:12 AM
JDMCivicHatch93's Avatar
im not sure for an Si but i have that kit on my 93 hatch, and i had the car too low and hit a bump in the road and now i have to dents at the top of my shock tower. they go through into the engine bay. but its not that big of a deal to me. it didnt hurt anything really.
Old 03-10-2003, 09:33 AM
sleeprhatch's Avatar
Default Re: Skunk2 Camber Kit...will I have clearance problems? (JDMCivicHatch93)
i got it on my ek and have not had a problem yet. i have it almost 4" lowered
Old 03-10-2003, 09:34 AM
Default Re: Skunk2 Camber Kit...will I have clearance problems? (sleeprhatch)
I believe eg's are the ones having the clearence problems
Old 03-10-2003, 10:21 AM
M-EJ1's Avatar
I don't want to be a thread pisser, but I really wouldn't recommend the Skunk2 arms for one simple fact: the ball joints included suck, and unless you call Skunk2 directly, you can't get a replacement (and even then I've heard that they can't or haven't been able to get any from their suppliers).
I didn't have the kit on for more than 6 months and the ball joints went bad. I ended up replacing them with OEM ones, I had to cut apart my stock arms to get them out, then grind down the hat on the top so it would fit in the skunk2 arm. Not the best solution, but hopefully these will last a little longer than the junk they include with the arms.
If you're really set on them, you shouldn't have any problems on your car that you wouldn't have with stock arms. If your suspension is fairly soft you might reconsider, but you should be alright if your ride is somewhat stiff.
[Modified by M-EJ1, 11:24 AM 3/10/2003]
Old 03-10-2003, 11:30 AM
Default Re: Skunk2 Camber Kit...will I have clearance problems? (M-EJ1)
This might be a stupid question but how do you know if your ball joints are bad? My skunk2's have been on the car for almost a year and I don’t seem to have any problems with them except the clearance issue which I took care of by raising my adjustable a little.
Old 03-10-2003, 03:42 PM
Bump for other opinions.
Old 03-10-2003, 04:26 PM
Lord Helmet's Avatar
ball joints are bad when you see grease coming out of the torn boot. or the rubber boot coming off or if the ball joint starts to make weird sounds.
Old 03-10-2003, 04:28 PM
Fuster_Cluck's Avatar
I hope not!
I had the skunk2 kit on my Ek and was dropped pretty low. NEVER had any problems with the kit hitting anything. Just the boot tore after 6 months. I made a thread about it if you care to look: https://honda-tech.com/zerothread?id=346142
[Modified by Hybrid93Hatch, 8:29 PM 3/10/2003]
Old 03-10-2003, 04:30 PM
92civicsi's Avatar
Default Re: Skunk2 Camber Kit...will I have clearance problems? (sleeperciv)
i wanna know this too
but i have a 92 civic si
hers how its sittin right now.
i just lowered my car and i have not got an alignment yet. if i do will they rub?
Old 03-11-2003, 10:27 AM
i hate my team's Avatar
Default Re: Skunk2 Camber Kit...will I have clearance problems? (92civicsi)
i have the kit on my car and it sucks *****! the arm keeps hittin up top and im on h&r race and tokicos... the boot tore immediately.... makes a knock noise when i hit a mild bump because the arm is hitting up top. but i still ride on them
Ej8_KiD
10
05-24-2009 06:34 PM
bigBOI_92DA9
03-18-2004 09:04 PM
migs
07-28-2003 08:50 PM
i hate my team
14
04-22-2003 11:33 PM
dLo GSR-stolen-now-WRX
07-05-2002 10:33 PM
Quick Reply: Skunk2 Camber Kit...will I have clearance problems?
