skunk 2 vs golden eagle vs obx
I'm fairly new to the scene and wanting to get opinions one these intake manifolds
skunk 2
golden eagle
obx
set up:
stock gsr block/ head
cheap ebay turbokit
hondata s300
660 injectors
stage 4 6 puck clutch
walboro fuel pump
aem fuel rail
also what size throtle should I go with?
skunk 2
golden eagle
obx
set up:
cheap ebay turbokit
hondata s300
660 injectors
walboro fuel pump
aem fuel rail
Re: skunk 2 vs golden eagle vs obx
All I caught out of this was the above.
I'll buy your currently running GSR for 500$ before you blow it up with an ebay turbo kit
That's 500$ net profit man!
Alternately; as Grumble mentioned, stock will suffice for you; if you INSIST on changing it and it's not in an actual Integra GS-R using it's OE ECU, the butterflies wont work properly anyway, swap over to a B16 throttle body and save yourself a mint.
dont really have a power goal or a dyno to check but hoping to hit mid 12's on the track
it would be nice if people keep negative comments to themselves
what are the pros and cons between the skunk2 and golden eagle?
I was told that with the golden eagle I would lose bottom and mid range power over a skunk 2
golden eagle has no plenum in the intake like oem or skunk2 intake. golden eagle is made for very high hp setup. Waste of money if your not planning to run high hp
There was a thread on here a while ago about some guy trying to prove his oem gsr im couldout perform many of the "off the shelf" intake manifolds. Justtake the butterflys out, shouldn't be hard to get 12's. What clutch and trans you running?
Ultracoupe
03-19-2017 08:45 AM
