Skunk 2 Stage2 cams and compression numbers...
i have an ls block with a gsr crank, CTR pistons and a p&p head milled .30. i assume my compresion is
about 12:1 give or take a few. i got itr cams right now but i plan on running skunk stage2.
do i have enough compression to run those? i know you need to tune them, but i hear stories about
these cams not performing well cuz of low compression or other stuff. basicly i just wanna know your
thoughts on my setup.
im sure youve heard this question before, but i searched ad didnt find what i was looking for.
thx
thx
Re: Skunk 2 Stage2 cams and compression numbers... (allmtr)
12:1 sounds like a pretty good CR to run the Skunk stage 2's. Any higher and the crappy 91 octane we get here in CA isn't gonna cut it. What happened to the B16??
Re: Skunk 2 Stage2 cams and compression numbers... (EKology)
hey man. whats up? i remember u from the fudruckers meet. i just swaped it out last week. my new setup it great. it just need to be tuned.
Haha, how you been?? Yeah dude, that sounds like a killer set-up, but tuning is the key!! Post up some dyno sheets!!
12:1 is good for the stage 2's, I'm going to be running a lower compression than that, when mine go in.
thx for the replys. um... hey EKology.. when are you going to the next HT meet.? i havent been to one in a long time. this is actually my first time back on HT in a long time. i was thinking of going on the one on may 4th...
Welcome back, haha! There's one coming up on May 4th, that one's gonna be cool, drop by for sure!! Rodrez, that goes for you too (It might be a little far for you though )
kewl. then ill see you there. um.. thx for the reply fusion. did u tune it. does it pull unbelievably hard in vtec???
I can understand if you're worried about the rod/stroke ratio or whatever..but I'm curious on why you have a GSR crank in your LS bottom end?
Re: Skunk 2 Stage2 cams and compression numbers... (FusionEg6)
If you don't mind me asking, what kinda valve springs do you guys run with your skunk2 stage 2's? I have porftlow valve springs currently in my car and was wondering if i should switch those out for skunk2 valve springs? Also, would running 11.6:01 be enough compression to get good results with these cams? Or is it better to stick with the stage 1's when compression is <12.0:01?
Re: Skunk 2 Stage2 cams and compression numbers... (Mr Hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Hybrid »</TD></TR><TR><TD CLASS="quote">If you don't mind me asking, what kinda valve springs do you guys run with your skunk2 stage 2's? I have porftlow valve springs currently in my car and was wondering if i should switch those out for skunk2 valve springs? Also, would running 11.6:01 be enough compression to get good results with these cams? Or is it better to stick with the stage 1's when compression is <12.0:01?</TD></TR></TABLE>
Get the Skunk2 valvetrain upgrade. 12:1 would be good compression for stage 2, you can run a little higher though.
Im using portflows. It's the same **** so if I were you, I would leave it, unless you got money up the ***. 11.6 is fine with the stage 2's. It depends too of how much power you really want. If I didnt use my car to go up and down LA so much, i wouldve go the stage 3's.
I have some stage 2's sitting in my room right now.
My compression is about 11.4:1 in my lsvtec. That should
be enough.
be enough.
