skunk 2 intake manifold?
just wondering whether has anyone used this on a B18C1 engine with basic bolts ons and if so what are your impressions on the intake manifold.
thx in advance. any feedback would be appreciated
Re: skunk 2 intake manifold? (civicgsr96)
Its a very worthwile investment... The stock GSR intake manifold is so bulky. The weight difference between stock and the skunk2 mani is really incredible. On top of that you gain around 6-7hp I believe...
The Fly - where in the rpm range do u feel the biggest difference between the stock intake mani and the skunk one?
I felt a big difference when I swapped my mani. The Skunk2 adds some midrange, but mostly after VTEC kicks in, you'll feel a big difference. Good investment
Re: skunk 2 intake manifold? (rodrez)
rodrez - thx for your input. just want to know what other mods did u have on engine. this way i can compare my mods with yours and to determine the difference if i do decide to put the skunk 2 intake mani on. thx
Re: skunk 2 intake manifold? (LSturboHB)
piggy-backin on civicgsr96's thread, what you all think is better Type R intake mani or the Skunk2 ?
Re: skunk 2 intake manifold? (TheFLY)
My Hatch with b18c1 had jdm dc header, 2.5" custom exhaust, and an ITR AEM CAI. When I bolted on the skunk manifold, I felt no loss in bottom end at all, totally identical. The motor needed vtec to be raised higher though. I could FEEL the motor fall flat when it first hit vtec at 4500. But after around 5500rpms the thing just takes off.
with i/e/h and skunk manifold I ran 13.91@99mph in my full interior hatch w/ street tires. and i put down 159whp and 121lb ft of torque.
The skunk2 is basically a typer mani I believe
Re: skunk 2 intake manifold? (cr00klyn718)
so basically the skunk2 is the same as the ITR mani?.is this true???
Re: skunk 2 intake manifold? (B-series Assassin)
so the victor x has a very noticable difference over the skunk2 im if so i migh tgo that route what is the cost difference
thanks
chris
thanks
chris
Basically yea, they made it where you dont have to do custom work to make it fit like the real Integra Type R manifold.
Did you guys get a check engine light after installing the skunk manifold? I heard that you get one because of the secondaries not being there. Of course this ? is for people with stock ecu.
Re: skunk 2 intake manifold? (96b18c1vic)
Does it your stock thorttle body bolt right up to the manifold without having to port match the size?
[Modified by TheFLY, 3:33 AM 5/30/2002]
1 Post
I'd make sure that you include tuning and a header when you purchase the Skunk2 manifold.
Right now I'm running Skunk2 with stock header and it sucks. I can just feel the power die. Tuning would help out a lot I imagine.
Re: skunk 2 intake manifold? (fowler)
The Skunk2 intake manifold isn't the exact same thing as a Type R intake manifold. The design was based off of the Type R intake manifold. Skunk2 has slightly bigger ports I believe.
Re: skunk 2 intake manifold? (hybridreams)
Which ECU and program will be best for this? I hear the P28 with Mugen is good for Skunk IM. Let me know.
Re: skunk 2 intake manifold? (Jun)
from the programs tested a stock ecu (p72) does very well, but it will require a VAFC or vtec moved to 5200-5500rpm range
Mugen is excellent, it adds few horses throught out the rpm range
