Tach not working need help
Okay after extending the driver side harness and replacing the cabin harness my tch no longer works I installed it in a friends car so i know it works I also have no breaks in the blue tach signal wire I also replaced the icm in the distributor what could be the problem how can I narrow this down car is a 94 civic si with gsr swap thanks
Re: Tach not working need help
Sometimes the tach just goes bad, on my 92 EH3 I had to tap the cluster to get the tach to register, swapped out the cluster with a VTi and problem solved.
So if your sure the wire is good from the dizzy to the cluster plug, than that would be my guess.
Ya the solid blue wire behind the cluster do u know where I can find a pin out for the driver side harness I can only seem to find the passenger side
PINKS
05-11-2006 05:36 PM
