single cam boost help!
I got a dx non-vtec d15b7 and i wana go on boost, and i heard that i could with stock internals and stuff and i would be fine if i tune around 5psi. whatelse do i need or what?
any help, comments, or suggestions??? |
Re: single cam boost help!
I know it'll happen, so I'll just get it over with. Use the search button.
Get bigger injectors, slap the kit on there and get a good tune. Done. |
research! and check out the forced induction forum
someone else recently had a very similar question for there y7. lots of stuff i've already covered in there that will help you with your questions. https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/wanna-boost-my-d16y7-2727504/ |
Thats guys, sorry little new to the siite will search and hopefully find what i need
1. Go to the Forced Induction forum
2. Read the FAQ 3. If you still have questions, search the forum a little 4. IF, after all that, you have questions (which you probably will) then ask Some people in the Model Specific forums are a little iffy on their responses related to forced induction. That's not to say you won't get good help, but you may have to sort through a few bad responses to get your answer. Try FI...you'll get what you need |
