Single belt conversions?
Old 05-25-2014, 08:43 PM
California98Civ's Avatar
Default Single belt conversions?
The aftermarket crank pulleys for a single belt conversion seem to be for the DOHC engines only. Can the pulley for a DOHC engine fit a SOHC 1998 Civic? Anyone know of aftermarket single belt conversions for the SOHC sixth gen Civics? Thanks.
Old 05-25-2014, 08:54 PM
Master Detailer
98civdx's Avatar
Default Re: Single belt conversions?
Unorthodox racing makes a crank pulley for them.
Old 05-25-2014, 09:03 PM
Are you sure? Because I am only seeing options for the 1992-1995s and the 1999-2000 Si... not the 1998 DX. The 1999-2000 Si is DOHC, right? Will that crank pulley fit the SOHC?
Old 05-25-2014, 11:43 PM
Stancetard Hate Monger
eghatch9295's Avatar
92-95 should work, dohc will not.
Old 05-26-2014, 07:49 AM
Thanks for the responses! I might try a SOHC 1992-1995, but I might also try having the existing crank pulley machined to carry just the single belt, because I don't want underdrive, just reduced rotational mass since I removed PS and AC permanently. These guys are nearby and can do the machining for about $100: http://www.inlinefour.com/infourn1encr.html
Thanks again!
Old 05-26-2014, 10:33 AM
Master Detailer
98civdx's Avatar
Ah ****. Looks like I read the description wrong. THey definitely make them for 96-00, but I can't find one for a single belt.
If you can get the stock one machined, and you are comfortable with that, I would go that route. That way you could keep the stock timing marks, and still be able to use the factory tool to remove the pulley.
Old 05-26-2014, 07:13 PM
make sure theyre a respected shop. needs to be perfect.
Old 05-27-2014, 02:23 AM
underrated's Avatar
ATI makes one for the d.
Old 05-27-2014, 06:20 PM
I never narc'd on nobody!
NotARaCist's Avatar
I've seen some pretty stupid **** before, so just to be clear...you do realize the single belt pulley is for deleting your power steering and keeping your alternator, right? Just want to make sure you don't think you'll be able to use a single belt for both.
Old 05-28-2014, 08:35 AM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
Thanks again!
Old 05-28-2014, 09:08 AM
sikefcrx89's Avatar
You could save yourself a lot of money by picking up a used D pulley and have it machined down.
Old 05-28-2014, 10:02 AM
Master Detailer
98civdx's Avatar
he said he removed both PS/AC...
Old 05-28-2014, 10:14 AM
NotARaCist's Avatar
Like I said, seen some pretty stupid ****...sometimes I'm stupid, too
Old 05-28-2014, 08:23 PM
All good suggestions, guys. Thanks.
Old 05-30-2014, 11:02 PM
Two single belt pulleys with vastly different weights and prices:
Unorthodox's $237, 1lb, underdrive http://www.unorthodoxracing.com/crank-pulley-4743
Ralco's $99, 1.5lb, underdrive https://www.ralcorz.com/RalcoRZ-914865/
Is the Ralco properly balanced/dampened? Anyone used it?
Old 05-31-2014, 08:43 AM
Seagull Management
94EG8's Avatar
92-95 should work
They don't or at least the OEM ones don't. The plastic lower timing cover is different and the pulley rubs or doesn't clear. I can't remember exactly but I have tried it and it doesn't work.
Old 05-31-2014, 10:27 AM
underrated's Avatar
I don't think any of those under drive pulleys are dampened. Because of that they were causing issues with the crank. Try and google it.
Old 05-31-2014, 09:03 PM
Here's an interesting read from a guy who says the pulleys will not harm a relatively stock, non-harshly driven, inline 4. That dampers are mainly for noise reduction:
http://www.fitfreak.net/forums/2nd-g...tml#post820681
b20accord
01-01-2009 08:24 PM
dbailey
12
03-17-2008 07:16 AM
Crit
08-23-2004 10:50 AM
Stock@$$GSR
05-12-2004 07:31 PM
Quick Reply: Single belt conversions?
