silly question...
silly question...
But I need to know lol, on my 95 civic my reverse lights do not work and some of my interior lights do not either, for example my A/C back lights and lights on my radio...could it be a fuse is out or a wire loose? any help is appreciated, thanks in advance
Re: silly question...
umm well 1st check your fused with a volt meter use the ohms to check them for resistance. they can look fine but be bad i promise you that. next thing after that id check si grounds and then loose or shorted wires.
the bulbs could be out, the wires could be loose... or broken, the fuses could be bad...
grab an electrical troubleshooting manual at the autoparts store.
its not the bulbs because I switched them around and they still work and the fuse is good. I have polyurethane mounts so maybe they vibrations knocked something out or shortened a wire?
