Significance or a tachometer with the 4-6-8 adjustment
Location: With my POS D15B2, Whereever whenever, United States
I just bought a autogauge small tachometer and it doesn't have this adjustment.
Can I assume it will work for my 4 cylinder>?
thanks
thanks
Re: Significance or a tachometer with the 4-6-8 adjustment (MugenHonda)
There loops on the back you cut to make it into said tach, depending on your motor 4cyn. - 8cyn. I belive they all get cut for a 4cyn.
Check out autometeres website its not the easiest to navigate if your looking for a manual but there all on there.
Re: Significance or a tachometer with the 4-6-8 adjustment (nocturnaldragon)
i bought it used
nothing to cut?
nothing to cut?
this is the tach i got
Operates on 4, 6, or 8 cylinder engines with points, electronic, and most 12V high performance racing ignitions.
What does this mean
What kind of motor was it hooked up to before? If it was a 4cyn then no you dont otherwise theres some brown? colored loops which you have to cut, well thats how you did it on mine when I had it installed.
Whats the model number so I can check the site out once?
It's the cheap one
Mine are all cut, if there were any hoops
I'll hook it up and see what happens
team2n1hatch
06-17-2003 02:04 PM
Ri5e
09-25-2001 09:25 AM
