!!!!!!!!!!!-side marker wiring prob (already tried searchin)-!!!!!!!!!!!
i just installed jdm stanley side markers on my eg wit the bulbs n everything. It looks good and all but the only problem iz that when i purchashed the stuff i got no wires or anything like that and now i have no clue on how to wire the side markers ...i tried searchin...i would like to have side markers that actually work so if anyone can help me plz
Re: !!!!!!!!!!!-side marker wiring prob (already tried searchin)-!!!!!!!!!!! (YayAreal2acer)
Do you have a picture of the bulbs/plugs? If so post them I am sure I can point you in the right direction.
Re: !!!!!!!!!!!-side marker wiring prob (HuntsvegasHatch)
i have the OE CTR stanley side markers... they should have 2 male quick connect tabs on them. doesn't matter what goes to what FROM the side marker, but here is the wires you should jump into for the different light effects... JDM or USDM. the difference is with USDM, they only blink with your blinkers... on JDM they're always on w/ parking lights and blink alternately with your blinkers (ie. when parking lights are on, they're on... when your parking lights are blinking, they're off). i had mine wired "JDM" for about a week before i realized it was retarded.
USDM:
Tap into green(turn signal) and black(ground) wire.
JDM:
Tap into red(parking light) and green(turn signal) wire
that is from a how to on clubsi.
EDIT: Link to thread - http://forums.clubsi.com/showf...art=1
USDM:
JDM:
so i just wire the red and green wire to the side markers? dats it? bcuz i thought i needed a wire kit /harness for the sidemarkers...and yes my bulbs got 2 male connect tabs
Re: !!!!!!!!!!!-side marker wiring prob (YayAreal2acer)
yes... just connect to ur existing blinker wires according to what the other dude said.. really simple..
Re: !!!!!!!!!!!-side marker wiring prob (EeeJayEight)
i really want my sidemarkes to work but i still just dont know how. i found the wires under my hood but how am i supposed to connect them to my side markers? also i dont think they are long enough too. how am i supposed to "tap" the wires?do i also JUST use the stock wires, so i dont need to buy anything else? im so confused ****
sry im noob
first time trying to do this shiet
sry im noob
there are these things called "solderless connecteors"
the one u need is one that will have one will look like a rectangle with two cylinders...
just go to home depot or something and tell them u need a connector to tap into a wire on an existig loom
go to a auto parts store and get some wire, electrical tape, and solderless connectors. you will also need some wire cutters or strippers to complete your job.
Re: (YayAreal2acer)
your dont need wire strippers or anything... there are connectors, i think they are called piggyback connnects that just connect two wires with a little metal connector that doesnt cut through the wire..very helpful
HT Order of Merit
Re: (EeeJayEight)
DO NOT USE ******* T-TAPS. Also called scotchlocks. ****, dont even use solderless connectors. NOTHING makes as good of a connection as solder. And if you dont know how to wire, dont do it. Just have someone who does do it.
messeduprex
11-27-2004 10:36 AM
