is this an Si for sure
Old 03-20-2003, 04:01 PM
New User
hondas2k's Avatar
Default is this an Si for sure
Looking at a '97 Del Sol with 36,000 miles. It does not have any stickers on the back other than del sol. Engine code says VHN1.6VJGKEE. Any way to tell if this is an SI for sure?
Thanks,
Kirk
Old 03-20-2003, 04:06 PM
TXDelSol's Avatar
Default Re: is this an Si for sure (hondas2k)
You could look at the engine code instead of the VIN # (i think thats what u looked at) and see what it says or just look under the hood. And r u hoping that it is an Si for sure cuz i would be hoping for the VTEC model which is DOHC b16 and the Si is a SOHC d16 but NEwayz thats the difference. And if u pop the hood and it is single cam and it doesnt say VTEC at all on the valve cover then it is an S model. That should help. Later
Old 03-20-2003, 04:08 PM
Global Moderator
Jimmy's Avatar
hmm...thats not the engine code try looking to the left of it & if its a 1993 si it should say D16Z6 which is a sohc vtec..
Old 03-20-2003, 04:45 PM
Happyman's Avatar
Default Re: is this an Si for sure (USDMDC2)
My valve cover doesn't say VTEC on it but it's a D16y8. I suppose not all Si valve covers had VTEC on them.
[Modified by Happyman, 8:46 PM 3/20/2003]
Old 03-20-2003, 05:22 PM
UpstateCivic's Avatar
Default Re: is this an Si for sure (Happyman)
Neither does mine.
Old 03-20-2003, 05:26 PM
Global Moderator
Jimmy's Avatar
Default Re: is this an Si for sure (UpstateCivic)
I didnt say that if its an si that it would say VTEC i said that if its an si it should say D16Z6 and a D16Z6 is a sohc motor..
Old 03-20-2003, 08:51 PM
DA_KengV's Avatar
If you look under the hood, you should see that it's either a SOHC or DOHC. If it's a DOHC, you have a B16. If it's a single cam and the valve cover says VTEC then it's an SI. If not, then it's just a single cam S. Your motor is newer so the valve cover should have VTEC on it, if so it should be the D16Y8 if it's sohc vtec. Hope you find out what you bought
Old 03-20-2003, 08:54 PM
poison's Avatar
Default Re: is this an Si for sure (DA_KengV)
93 del Sol Si's came with the D16Z6 having a black valve cover with an H badge. (this is the best looking IMO)
94&95 Si came with the D16Z6 saying VTEC on the valve cover.
96&97 Si's came with the D16Y8 saying HONDA on the valve cover.
Only way to tell is by the engine code & or looking for the vtec solenoid.
Old 03-20-2003, 09:17 PM
B16b2b's Avatar
del slow vtec: b16a
92-95 civic ex/ 92+ del slow si: sohc vtec, and only SOME of them say vtec on the sohc valve covers, regardless if they are indeed vtec motors.
Old 03-20-2003, 09:19 PM
B16b2b's Avatar
Default Re: is this an Si for sure (poison)
did they all come with 4 wheel discs? i thought that was an si-model only thing.
Old 03-21-2003, 08:32 AM
New User
hondas2k's Avatar
Seems to be an Si since it has a 7200rpm redline and that EH6 in the VIN is supposed to make it an Si. I will look at it again today to check these other things but after driving it, I am sure that it is not a S and pretty sure it is not a VTEC.
Thanks,
Kirk
Old 03-21-2003, 10:49 AM
day1si's Avatar
First what is the price on it, that usually will tell you if it's a VTEC or not.
So are you looking for a VTEC, or an Si?
VTEC = 1.6 DOHC 94-95 B16A3 96-97 B16A2
Si = 1.6 SOHC 93-95 D16z6 96-97 D16y8
Both have vtec, one is just a DOHC and one a SOHC. The VTEC model is what is usually sought after.
4 wheel disc brakes came on all of the Si's and VTEC models, and had the option of ABS begining in 95.
The VTEC redlines at 8100 and the SI I believe at 7400.
What you gave looks like part of the VIN #. If you have the whole VIN# I can tell you what it is.
:edit: You say it's EH6?
EG1 = Civic del Sol, 1.5L
EG2 = Civic del Sol VTEC 1.6L
EH6 = Civic del So, 1.6L
So yes it's an Si
[Modified by day1si, 2:02 PM 3/21/2003]
Old 03-21-2003, 10:56 AM
Former Moderator
B18C5-EH2's Avatar
Wrong.
The only SOHC Del Sol with "VTEC" on the V.Cs will be the 1994-1995 models.
1993, 1996, and 1997 will not say "VTEC" on the V.C, so you're wrong in saying that if it doesn't say VTEC it's not VTEC.
The 1993-1995 had the 125hp SOHC VTEC D16Z6 motor while the 1996-1997 had the 127hp SOHC VTEC D16Y8 motor in them.
If you don't know what you're talking about, please do not post "helpful" info in your posts. You could cause someone not to buy or buy a car because they trusted your "advice" even though it's wrong.
lowblackdub
09-20-2012 06:13 PM
deeice30
11-02-2006 05:15 PM
schnaeringer
05-26-2004 03:05 PM
slow_95_accord
09-22-2003 08:10 AM
thinkbrianthink
09-01-2001 04:47 PM
Quick Reply: is this an Si for sure
