Si rim tire sizes
Si rim tire sizes
I remember reading on here a while back about the particular tire sizes people were running on 99-00 Si rims w/out any rubbing issues.
Time has come for me to replace my tires, but now I cant find the thread about what sizes people were running. I know stock size is 195/55/15 but I vaguely remember people saying 205/50/15? or something similar to that.
Any help would be appreciated, thanks!
Re: Si rim tire sizes (HyBriDcxR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HyBriDcxR »</TD></TR><TR><TD CLASS="quote">205/50-15 is right.
It'll rub on tight turn and depending on how low you are.</TD></TR></TABLE>
That's what I'm running on pro-kits. No rubbing except occasionally at full lock.
Re: (Vtecin94dx)
I'm lowered about 1.8" (s-tech) right now.
Only rub when the steering wheel is almost fully turned.
But not as bad as back then cause i've worn the lining down now.
Re: (HyBriDcxR)
205/50/15's on Neuspeed race springs (2.5") w/ stock shocks..........
no rubbing at all
actually, when i first dropped it with these rims/tires, the front fender lining rubbed a little, but i just tucked it up further and everythings cool now
Modified by crx_91si at 5:30 PM 5/12/2004
Re: Si rim tire sizes (Tw1n Turb0 Z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tw1n Turb0 Z »</TD></TR><TR><TD CLASS="quote">I remember reading on here a while back about the particular tire sizes people were running on 99-00 Si rims w/out any rubbing issues.
Any help would be appreciated, thanks!</TD></TR></TABLE>
just want to let you know if you are considering falken azenis sports their 205/50/15 actually measure 219 across
Yeah just about any 205 should be fine. The azenis do measure about 15mm wider then their "advertised" rating on all of their tires.
I never had any problems on my old 99si with azenis on stock si wheels as well as 6.5" group n's unless you were transitioning VERY quickly (i.e. auto-x) and the only reason for that is lack of dampening and spring rates. Had slight rubbing on the inner fender liner.
Re: (crx_91si)
exact same setup as mine and i dont seem to rub any <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_91si »</TD></TR><TR><TD CLASS="quote">
no rubbing at all
actually, when i first dropped it with these rims/tires, the front fender lining rubbed a little, but i just tucked it up further and everythings cool now </TD></TR></TABLE>
no rubbing at all
Re: Si rim tire sizes (Huggy Bear)
i am lowered 1.5 inches and no rubbing at all with my 15 x 6 rim with my 205-50-15 azenis keep in mind i put them on yeasterday
vtec_yosh
02-09-2004 12:48 AM
