Si front upper strut bar
Re: Si front upper strut bar (00 EK9)
center it on your shock towers and drill holes. Use bolts, nuts, washers to mount it.
If you look at the top of your shock towers, you should see some faint indentations. that is about where you want to mount it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 EK9 »</TD></TR><TR><TD CLASS="quote">aHh...i have to do drilling. Thanks tonyXcom.</TD></TR></TABLE>
No problem. The SI is the only 96-2000 civic that actually came with the studs from the factory to mount the tower bar.
Re: Si front upper strut bar (tonyXcom)
sorry to bring this back from the dead so the bolts that are in the inner fenders can not be bought?
So do you just use any type of nut and bolt combo that will fit though the stock holes?
Thanks
Accordhybrid
Thanks
Accordhybrid
Re: Si front upper strut bar (accordhybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordhybrid »</TD></TR><TR><TD CLASS="quote">sorry to bring this back from the dead so the bolts that are in the inner fenders can not be bought?
Thanks
Accordhybrid</TD></TR></TABLE>
yea, you just lay the bar out, drill some holes, and put nut and bolts on.
it's easier then changing oil
Thanks
Re: Si front upper strut bar (JICEK9)
I wrote this up for my EG really just as an excuse to take pictures. It already had the holes but the process should be pretty much the same.
http://spoon.org/civic/Shock-Tower-Bar.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordhybrid »</TD></TR><TR><TD CLASS="quote">thanks also one more really quick question is there any difference between the SI and the GSR?</TD></TR></TABLE>
GSR makes you go faster
...on a serious note NO there the same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom »</TD></TR><TR><TD CLASS="quote">
No problem. The SI is the only 96-2000 civic that actually came with the studs from the factory to mount the tower bar.</TD></TR></TABLE>
? 96-00 Civic? You mean 99-00?
What do you mean studs? As I recall I just took off the bolts on the strut tower and put the bar on, and re-replaced the bolts.
