Si cluster swappers
Si cluster swappers
i just put my new cluster in and the cruise control light is annoying the **** outta me, it flashes on and off constantly (my car is not auto), what have you other swappers done about this, or do you just ignore it?
Re: Si cluster swappers (emoney9)
A 99-00 si cluster i am assuming??? If so, do you have the 99-00 harness? If not you may have miswired. I couldn't find anything in search so I don't think that it's a common problem. I wouldn't think it would be intermittent if it was cluster problem, I would check wiring.
Re: Si cluster swappers (GARBhatch.)
Im assuming its on his cx, wich had a shift light deal.(at least in the 5th gens)
The shift light was in the same spot the cruise control light is in, and used
the same wiring, so when the car says to upshift, it lights up the cruise
control light.
just take the bulb out.
control light.
Re: Si cluster swappers (elwood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elwood »</TD></TR><TR><TD CLASS="quote">Im assuming its on his cx, wich had a shift light deal.(at least in the 5th gens)
control light.
just take the bulb out. </TD></TR></TABLE>
Wow, I did not know this. That's pretty cool, but annoying.
control light.
Thanks a lot guys i didnt realize there was seperate bubs for each indicator light ill figure out which one it is and take it out
EDIT- BTW does anyone have or know where i can get some amber #74 bulbs? i have the #24's and no #74s to match
Modified by CXinthemaking at 8:42 PM 3/7/2004
Modified by CXinthemaking at 8:51 PM 3/7/2004
control light.
just take the bulb out. </TD></TR></TABLE> Wow, unaware of that. Just another lesson from H-T...
control light.
Re: Si cluster swappers (CXinthemaking)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CXinthemaking »</TD></TR><TR><TD CLASS="quote">Thanks a lot guys i didnt realize there was seperate bubs for each indicator light ill figure out which one it is and take it out
Modified by CXinthemaking at 8:51 PM 3/7/2004</TD></TR></TABLE>
Check this site http://www.autolumination.com.... Chris is a awesome guy!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GARBhatch. »</TD></TR><TR><TD CLASS="quote"> Wow, unaware of that. Just another lesson from H-T...</TD></TR></TABLE>
I learn something new everyday,
That's why I sit here and read through all the threads
