si cluster h-t help.
Re: si cluster h-t help.
possible but not a direct swap. there are people that have done it and i beleive there are issues about everything working correctly. you could search for the correct info but VB owns search now.........
its possible but you have to like cut and splice wires cuz the plugs are different. IMO if your not a pro with wires...dont try it.
wiring would not be a big deal. if i didnt get it right i have a guy who works for a honda dealer that could. my concern is more fitment in the dash thnx for the help still
i have seen it in an eg and you have to fab alot of custom plastic and ****. idk about the em1 but IIRC the shape of the s2k cluster is still very far off of the em1 cluster.
Your concern is not the fitment. Fitment is the easy part. IIRC the S2k cluster requires a few parts to convert signals that your Civic uses into signals that the S2k cluster will understand. The wiring is quite extensive and you'll need some very smart people to help you complete it successfully.
I'm not trying to discourage you, but this is an apples and oranges project. Best of luck.
I'm pretty sure it has been done on alomost all Civic gen's so you should be able to find a decent DIY on it somewhere. But yeah, it's a tough one.
yes it has been done and more than once here on H-T. i cant find the thread but it does fit. the cluster is actually smaller than the area provided so you would have to find a way to cover up the sides.
a lot of wiring involved but it fits in ek and eg. nothing new.
i personally rather read the needle but GL with the install!
scroll half-way down the page
https://honda-tech.com/forums/showth...ht=s2k+cluster
