should i go with a gsr or b16 head on my b20b
well i'm looking into building a std b20vtec with itr spec piston... which vtec head should i go with...
Re: should i go with a gsr or b16 head on my b20b
They are essentially comparable, in terms of performance.
The key difference is in the volume of the combustion chambers, which will affect the compression ratio. Do some research on where you want to be for C/R, the pistons you want to use -- then look for which head best suits your needs. The intake manifolds are different, so if you have some specific parts which you need/want to use, that may also have an influence in your decision.
L33TsAbabyEater
09-11-2006 06:53 PM
