shifter stabilizer bushings...eg2
Ok, been thinking about getting energy suspension motor mounts...wheel hop is my biggest complaint about this car, its really bad. Think these will help?
3rd gear grinds whenever I shift fast at a high rpm in 2nd, people have said the motor is moving around too much.
Would a "Manual Transmission Shifter Stabilizer Bushing Set" help this as well?
Re: shifter stabilizer bushings...eg2 (elevatethis)
my 3rd gear grinded in my ek. wonder if we are the only ones that had that problem. my engine had no power so i dont think it had trouble being stable
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elevatethis »</TD></TR><TR><TD CLASS="quote">Ok, been thinking about getting energy suspension motor mounts...wheel hop is my biggest complaint about this car, its really bad. Think these will help?
Would a "Manual Transmission Shifter Stabilizer Bushing Set" help this as well?</TD></TR></TABLE>
These will help but a traction bar will help much more.
Syncros are shot.
No.
Syncros are shot.
No.
Re: shifter stabilizer bushings...eg2 (ladysman)
listen to this man:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">and for the CORRECT ANSWER.........been 20 wrong ones so far.........
replace the rear tranny mount or use the ES inserts, also check the shifter bushings on the tranny.
Your engine is moving around on the high rpm shifts.
But what do I know????
More than the average bear!!!!!!!</TD></TR></TABLE>
taken from this thread here: https://honda-tech.com/zerothread?id=685068
I have the motor mount inserts, myself, with my d15b7, and i say there not too bad to install, but I never have put the one on the rear of the motor, it took me about 2 hrs. and couldnt get to it ( on the floor in my gurage ), but even with only two of the three, for thirty something dollars, i think its a great upgrade for the money, and traction did improve noticeably
Nevaeh
09-30-2004 03:18 PM
bushing, bushings, del, eg2, gsr, h22a, motor, mount, replace, shifter, sol, stabalizer, stabilizator, stabilizer, trans
