shift linkage too short??
Re: shift linkage too short?? (bdicustoms)
that should work just fine if they sent you the shif linkage from that motor? Most USDM linkages will not fit on a JDM motor. They will require a rubber bushing that fits over that lil shaft thing, then has the bolt and washers to work. The USDM's are just a bolt that goes into a threaded hole. Yea my descriptions are bad. but i'd think u should be golden. They are messed up if they sent the wrong shift linkage. I'd double check. Take pics if u can. I'll do my best to help. Show where it doesnt fit if possible
Re: shift linkage too short?? (fowler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fowler »</TD></TR><TR><TD CLASS="quote">You prolly got a b16 from a del sol. That shift linkage is too small. Any other 94+ b series should work fine.</TD></TR></TABLE>
Actually the del sol shift linkage is longer then the hatchback's for some reason.
1 Post
Re: shift linkage too short?? (starang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by starang »</TD></TR><TR><TD CLASS="quote">
Actually the del sol shift linkage is longer then the hatchback's for some reason.</TD></TR></TABLE>
my bad, I knew it was one or the other..
jdm_eg
10-06-2008 12:51 PM
