Shift linkage question?
I have a del sol with a b16 and gsr transmission with an ls 5th gear. Can I use any b series shift linkage with that?
Re: Shift linkage question? (bcod151)
you should be able to use the b16 linkages
Ok i was just making sure cause I have a problem with 5th gear popping out and it has a new gear syncros and the shift forks look ok to me I cant think of anything else to be the problem then?
No, you will NEED a 94-97 Del Sol VTEC (B16) shift linkage.
Any idea why the 5th gear would be popping out?
