shift linkage problem help pls
hey was up today i ran in to a problem with shift linkage.i couldnt take it off for some reason.The car is honda civic 92 hatch. is it usualy hard to take it off and what should i do.and yes I was gonna take the whole motor out let me kno aasp tnxs NEED HELPPP
hmmm thnxs for the help homiee i did everything except that i was trying to get that bitch out for an hour and i gave up wat kind of tool is the best to use and wat size t u kno
HT Order of Merit
Re: (crnimacak)
I used an air hammer. Took 3 seconds.
Also, if your just removing an engine, you don't have to remove the linkage from the transmission. Unbolt it from the shifter point and it will hang down while your removing the old engine.
Re: (JDM_Ej)
jack the car up really HIGH but use some jack stands for your safety and pound that bitch out.
or you can just pull out the motor with the linkage with it but just jack up the car really high.
Re: shift linkage problem help pls (crnimacak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crnimacak »</TD></TR><TR><TD CLASS="quote">hey was up today i ran in to a problem with shift linkage.i couldnt take it off for some reason.The car is honda civic 92 hatch. is it usualy hard to take it off and what should i do.and yes I was gonna take the whole motor out let me kno aasp tnxs NEED HELPPP </TD></TR></TABLE>
which part of the shift linkage u are having trouble with?
oh i got it all done man tnxs anyways it was a pin that conects trany with shift linkage i was just using a wrong size screw to get it out i was usin 10 insted of 12
