shift linkage?
what are some common problems that u may have with a bent shift linkage
Re: shift linkage? (92hatchboi)
anybody has any clues or problems with a bent shift linkage
makes it hard to shift gears and can cause wear and tear on the synchros that will make your tranny grind and have to be replaced sooner. just my .02
Re: shift linkage? (93egB16A)
it may also barely go into gear, making it jump out.
if u get under ur car and have some1 shift your gears while ur under there, and the swivel joints at the transmission are giving whats so ever, that could be ur problem. i had this problem and easily fixed it by drilling out the pressed pin and putting a bolt and nut with lock washer and had no problems shifting once again. got to use what ever u can when ur broke, lol. but this works. and plus honda is proud of their shift linkages
