She won't blow no more
Any of you guys ever replace the heater blower motor? This one has been making noise for a ling time and now won't come on. Just looking for some tips or help. The car is a 2000 Civic EX 5speed
Thanks
Thanks
Re: She won't blow no more (Zumo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zumo »</TD></TR><TR><TD CLASS="quote">Any of you guys ever replace the heater blower motor? This one has been making noise for a ling time and now won't come on. Just looking for some tips or help. The car is a 2000 Civic EX 5speed
Thanks</TD></TR></TABLE>
it'll consist of you removing the dash. once you do that, it's smooth sailing from there.
all i gots to say is have fun with this the whole dash must come out and the heater core is kind of a pain to take a off and replace mabey a 3.5 hour project with right tools
Re: (fmrprojects)
lay down the crack pipes about taking the dash off to get to the blower motor!!!
put your head under the passenger side of the dash and look up... see the thing that looks like a motor and has three 8/10mm bolts/phillips head screws in it... disconnect the wires going to it and remove three bolts... blower motor will fall on your head but you'll be a lot happier than if you had removed the entire ******* dash.
I'd still check the fuse first though and if that's good probe the connector for power before doing anything... if it was making noise then it probably is the blower motor
part no 4
remanned ones only come with the motor... the hampster wheel is a small pita to get off... involve the use of a hammer...
part no 4
Re: (undercoverdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undercoverdc2 »</TD></TR><TR><TD CLASS="quote">lol good luck. it's gonna take a few hours.. you probably got some stuff stuck in there, but it's a PITA to get to.</TD></TR></TABLE>
try 10 minutes from out to back in... do you guys even know where the blower motor is?
Solbros Owns Me
Re: (ek9bmxer)
HT= a bunch of retards that can't read and or/ don't know what they're talking about
the blower motor is under the pass side of the dash, held in by 3 8mm head screws. Disconnest the plug, remove the screws, and it will drop out(remove pass kick panel like mentioned for easier access)...thats it.
the HEATER CORE is on te firewall wall and needs dash removal in order to be replaced, NOT the blower motor
Re: (Evs-One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One »</TD></TR><TR><TD CLASS="quote">HT= a bunch of retards that can't read and or/ don't know what they're talking about
the HEATER CORE is on te firewall wall and needs dash removal in order to be replaced, NOT the blower motor</TD></TR></TABLE>
I'd take out the not being able to read part... it kinda makes you look retarded
corrado007
10-24-2007 12:22 PM
HondaGSX
12-17-2005 05:10 AM
Kristo92
10-21-2003 05:02 PM
