Shaking engine when cold. WTF?
Ok whenever I start my car and the engine is cold my car has this strange sympton that I can't figure out. If you let the clutch out at idle then the car will take off relatively fine, but if you over rev the car in the slightest, and try to go, the car shakes violently as if the engine were about to diem even though it isn't. If you really over rev it and go then it won't do it, but only b/c the rpm's are so high. When the car is warm this sympton usually ceases, but it still does it every once and awhile if you don't let it out just right. I have driven other Civic's and they don't do this at all. It drives me crazy and I would really like to know what the hell is the matter with it. I hope this makes sense. Thanks.
Re: Shaking engine when cold. WTF? (96 SOHC VTEC)
check ur plugs..dont really know though..this happen d to me and the plugs were black when the pull d them out..could also be a dirty fuel delivery sys. too
Re: Shaking engine when cold. WTF? (MiGs)
It needs a blanket. Damn, take better care of your motor!
Re: Shaking engine when cold. WTF? (willyboyD16)
sounds like the engine is missing. check your plugs and wires look at the plug ends of the wires if you see any whiteish powder streaks or cracks your plug wires are bad. also check cap and rotor
I think your car shakes because it isn't an ITR!!!!
Mike <---saying no flaming intended....we know each other. but yeah it is a violent shake when the car is cold.
same for me...but im pretty sure its the combo of the cams, ecu, tuning, and just being cold...if u dont have any of this, then check your motors stability.
96WhiteOnBlack
04-02-2007 03:45 AM
dsadas89das78934
03-09-2005 06:10 PM
