Serious Mystery (tranny related)
Old 10-07-2007, 09:13 PM
Zdyned's Avatar
Default Serious Mystery (tranny related)
Ok ill try to make this short...
i have a 97 ex civic coupe, my stock motor took a dump so i bought a wrecked 4D coupe also ex and swapped the motor and tranny, straight over swap
everything went well and the motor fired right up... here's the mystery
I drove the car about half a block down the road and it made this quite little noise nothing serious sounding, and now it just feels like it is in neutral...
I drove the 4D before the swap and the clutch grabbed hard. All the gears feel like they go in fine, and when you put it into fourth, the speedo even moves a little.
the axles are not moving at all but spin freely, no gears grind or feel wierd when engaged... help please im pretty stuck..
thanks
Sonny
Old 10-07-2007, 09:19 PM
DCSportEJ1Civic's Avatar
Default Re: Serious Mystery (Zdyned)
double check your axles. it sounds like they are not in all the way. you couldve had it in just enough to grab the spline but not actually locked in. then drove it and it worked itself back out.
Old 10-07-2007, 09:21 PM
Zdyned's Avatar
Default Re: Serious Mystery (DCSportEJ1Civic)
ill check that, they look all the way in and i know the nuts in the hubs are tight
thanks for the idea though
Old 10-07-2007, 09:30 PM
well to be more specific i meant all the way in the trans. i made this mistake once or twice. flat-bedded my car home and found out it was a quick 10 min fix. theyre a pain in the *** to get in all they way. and if you havent put an axle in before it easy to mis-judge weather its in all the way or not. anyway i hope this is your problem cause its an easy and most of all free fix. g/l.
Old 10-07-2007, 11:11 PM
Zdyned's Avatar
Yeah, thanks man, i've never put in a axle before, its tough...... anyone else???
drshottest718
10-06-2006 03:22 AM
VNTEC
18
11-28-2005 12:37 PM
Jwbetley
42
01-19-2005 10:06 PM
jadugartir
12-31-2004 10:17 AM
Rpc07
08-28-2003 06:01 PM
Quick Reply: Serious Mystery (tranny related)
