Secondary o2 sensor problems!!!!
Ok all im sure this topic has been exhausted but i cant find any results to the issue. 98 civic dx with a y8 swap. Vtec has already been wired in and knock and iacv has already been converted. The problem i am running into is my secondary o2 sensor. I looked at the pinout for it,wired it direct to the ecu, but the sensor is not heating up at all. The CEL immediately comes on after the car is started. Also the voltage is pegged at 1.275 volts. Even after the car gets up to temp, it still does not change voltage. I have tried this on 3 different o2 sensors and swapped the ecu out of a ex that had no CEL. The ecu is a p2p obd2a. Is there anyone that has had this problem and fixed it!!! I need to pass emissions!!!
Re: Secondary o2 sensor problems!!!!
Does anyone have any info or can lead me in the right direction?
What engine harness did you use?
There are 4 wires. Where did you run them to?
Have you checked whether fuse 15 is blown? |
Why didn't you just extend the factory one?
Its the y8 engine harness and the cabin harness is factory dx. I ran one heater wire to pin A5 (secondary heater control), the other heater wire to open slot in fuse panel(12v), black signal wire to d14, and ground to d13. I followed the pinout from http://technet.ff-squad.com/wiring.obd2a.htm. I wouldve extended the factory one but they arent on a factory d16y8 engine harness(ex). The y8's secondary is wired into the cabin harness and extends thru the floor. I have the dx trim and the two o2 sensors are wired into the engine harness. Ive tested the sensor with a multimeter and everything is in perfect order. I have even hooked it straight to battery to test the heater and it warms up. But if its hooked to the ecu it wont warm up.
open slot in fuse panel(12v) |
1 Attachment(s)
Sensor side of connector:
Both heater wires are black. The sensor input wire is Wht. The sensor ground wire is Lt Grn. |
Ok i was a little confused because you said you converted the IACV, the EX harness (unless you used an auto harness) doesn't need converting.
On my o2 sensor both heaters are white, signal is black, and ground is greyy
I tried hooking it up the same way as in the picture and same result. Will post a pic in a couple minutes
Its not letting me post a pic. Its above fuse 31 or 32. Its a single blade
Above fuse 32 & 33 is C929 which is Ign. 2 so that should be fine. With the wire colors you listed it would be an aftermarket sensor of some type. Is your sensor a "directect fit" with an OE type plug or universal that has to be wired in?
Have you checked for battery voltage at the sensor with the key on to make sure your connections are sound? What specific code are you getting? |
Yes it has oe style plug. Yes ive tried the voltage test. P0141
Or are you talking about the ecu side of the harness?
Could it be possible my ecu has a bad spot in it?
Originally Posted by 92siturbro
(Post 49562051)
(Post 49562907)
I used my code scanner and watched the live data. The voltage pegs at 1.275 volts and throws a heater circuit malfunction(p0141). The sensor does not warm up at all. I do not have an extra ecu. And the closest one i kno of that i could use is almost 2 hours away
Get a multimeter and use it to measure voltage at the heater power wire.
Ok i will pick one up in the morning and try it. I thank you guys in advance for all the help ypu have given me so far
(Post 49555585)
Here’s the pin locations: OBD2a 2nd 02 Sensor ECU Connector White Wire TO D14 – Sensor Heater 02 Signal (SH02S) Green Wire TO D11 – Sensor Ground 2 (SG2) Black Wire TO A5 – Secondary Heater 02 Control (S02HTC) Black Wire TO A11 – Power Source 1 (1GP1) |
Ok i will try that pinout and post results. Thank you!
Fixed!!!! I will be posting a tech article with what my buddy did to fix it. Thank you all for the help!!
(Post 49566456)
