Secondary O2 Sensor on OBD-2
Hey. Built a test pipe for my '00 Si and my secondary 02 sensor doesn't have a home now. Any ideas on how to keep my ECU from tripping code? Thanks for your help.
Re: Secondary O2 Sensor on OBD-2 (JDM B Series)
Some guys have ran a O2 emulator/simulator which basically tricks the ECU into thinking there is a perfectly fine O2 sensor attached.
Re: Secondary O2 Sensor on OBD-2 (acuracing)
just find a nut that fits the sensor, drill a hole in your test pipe and weld on the nut to it. then you will have a place for the sensor. i havn't tried this but this is what i am going to do when i make mine.
Re: Secondary O2 Sensor on OBD-2 (cjames235)
I wrapped mine in aluminum foil, and put it under the dash....works like a charm...no codes at all.
Re: Secondary O2 Sensor on OBD-2 (SuperDragII)
i got the simulator... 40 bucks no codes... 98Civic DX
Do you know the wrench size for the O2? I need to replace my but I need to buy a wrench. the adjustable wrench keeps sliping. Thanks.
Re: Secondary O2 Sensor on OBD-2 (Jun)
they sell a socket to take the o2 sensor off its like 10 bucks
Re: Secondary O2 Sensor on OBD-2 (vtec69)
they sell a socket to take the o2 sensor off its like 10 bucks |
I'll try the foil/dash trick, see how that goes. Thanks.
same size as plug wrench
Re: Secondary O2 Sensor on OBD-2 (shane Z)
Can you shed some info on where to get the Simulator?
Re: Secondary O2 Sensor on OBD-2 (95CivicEX)
.. and get some good lubricant and breaker bar maybe to get the sucker out.. it can be a hassle |
Re: Secondary O2 Sensor on OBD-2 (Chiovnidca)
On a similar note....how much do these sensor usually cost. I went to Auto Zone and the guy told me 239.00 for one of these, i told him that him and his computer are crazy, this idiot didnt even know how to pronouce Acura he pronounced it
a-ku-ra!! anyways how much do they really run for??? |
where did you buy the o2 simulator.. i need one
I wouldn't do the foil thing. I think you have these 2 options - 1. get yourself either a jdm obd2 ecu or a obd1 ecu; both do not utilize the 2ndary o2 obviously...2. get yourself the emulator.
Re: Secondary O2 Sensor on OBD-2 (vpc)
I wouldn't do the foil thing. I think you have these 2 options - 1. get yourself either a jdm obd2 ecu or a obd1 ecu; both do not utilize the 2ndary o2 obviously...2. get yourself the emulator. |
why, foil works fine. |
