SEAFOAM WORKS.........HIGHLY RECOMMEND
WOW SEAFOAM WORKS SOOOOOOOOO WELL. I'M SO SUPRISE. EVERYTHING IS SOOO MUCH BETTER...EVERYONE SHOULD DO IT!!! BOUGHT MINE AT AUTOZONE FOR LIKE 6 BUCKS. WELL WORTH IT.
Re: SEAFOAM WORKS.........HIGHLY RECOMMEND (underb00steg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underb00steg6 »</TD></TR><TR><TD CLASS="quote">seafoam ?? ...is that the stuff you put in between the panels and the actually car ???</TD></TR></TABLE>
I think your thinking of dynamat....
Anyways...
Yeah seafoam works
Anyways...
Yeah seafoam works
Re: SEAFOAM WORKS.........HIGHLY RECOMMEND (AbitAvenger)
Did you put it in the tank or performed a "hot soak" procedure?
If just in the tank, try the other way. I've learned this at a bmw techs board.
You suck seafoam in the workiung engine through the vacuum hose, then let the engine stend for a night and start it next morning, woooooooh.... Get it on the highway fast, it's, like new now.
cute little bastard
Re: SEAFOAM WORKS.........HIGHLY RECOMMEND (lv6l)
I didn't notice **** when I seafoamed my car. Just a shitload of smoke that I left in the nature center LOL
Re: (sbcs15)
yeah my fuel system has run liek **** latly do they make this stuff for the gas tank? or whats the deal to have it run threw my tank? if anyone knows post up plz im really itrested since i changed my pump injectors and filter and its still running kinda werid..!
Re: (biggentplayer)
1/3 in the gas tank
1/3 through the brake master cylinder
1/3 through the oil cap
Run it through the brake master cylinder first, being careful not to bog the car.
Add 1/3 of the bottle to the motor through the valvecover and go for a "spirited" drive.
Drain the oil, replace the oil filter/oil and spark plugs.
It helps get rid of all of the carbon deposits that build up on a motor from regular usage.
https://honda-tech.com/zerothread?id=1215326
follow the instruction to this thread if any of you guys want to try seafoam. cost like 6 bucks at autozone.
Re: (biggentplayer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggentplayer »</TD></TR><TR><TD CLASS="quote">Yea seafoam works great put it throught my brake booster line. Just remember after using seafoam BUY NEW SPARK PLUGS. All that carbon destroys them.</TD></TR></TABLE>
thats actually not true, it cleans all the carbon deposits on them along with your fuel injectors
Re: SEAFOAM WORKS.........HIGHLY RECOMMEND (sockvtec)
crank case, i know this is really n00b, but is that just putting it in where the engine oil goes? BB and fuel i can understand, i guess im just double checking...
Re: SEAFOAM WORKS.........HIGHLY RECOMMEND (wwang924)
You can go a dealership, that is a BG chemical supplier, and have a BG Induction flush done. Its the same thing as seafoam except safer and more reliable. The only downside is the cost.
Re: (ikayto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ikayto »</TD></TR><TR><TD CLASS="quote">when you're going on the spirited drive
doesn't it attract attention from the police because of the smoke?</TD></TR></TABLE>
If it does, they can't do **** about it. What are they gonna say? "Son I pulled you over cause your car is smoking to much." As if there is a law on how much physical smoke a car puts out. As long as it passes the sniffer every couple years it doesn't matter what comes out of the tail pipe.
Anyways, Seafoam kick's *** in my book.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00EM1 »</TD></TR><TR><TD CLASS="quote">i dont like seafoam</TD></TR></TABLE>
Wanna explain why?
Wanna explain why?
