screws on rotors
screws on rotors
Im about to change my brakes, and i hade a bit of trouble last time i tried to change them.
they stripped out prety bad, and need to be drilled out. i was wondering it there was a replacement
at autozone or if i needed to make a trip to honda. if so, anyone have apart #?
and while were at it, is there any suggestions for tapping out a stripped screw?
thanks all. you guys are always a big help.
Re: screws on rotors (Convert)
u don't need those screws they r for the assembly line to hold the rotors in place. your rims hold them on. save the couple bucks and headache of tapping them.
Re:
people who strip them out don't know what they are doing, first off you need the right tools one being a torch so you can heat around the screws on the rotor but don't heat directly on the screw it will make them too soft and they will come out a lot easier and the other tool you will need is a reversible impact driver that you smack it with a big hammer to knock it loose and yes I was able to reuse those screws, you can get the torch anywhere they sell plumbing supplies and the impact driver I bought over at advance so I would think that most other parts stores will carry them.
bottom line use the right tools to do the job once
I've been drilling the screws out for years. Start off with a small drill and step up to a 3/8 drill. Drill the head and hit the rotor from the back to pop it off the small amount of screw left. Then the screw comes out by hand.
I have tried the heat and the impact tool. the drill works best for me. I've done this so often it takes about 5 min's each.
Re: Re: (Kista20)
kista k20:
I do agree about doing it right. however, Im confused on the part about leaving the screws out. is this safe? My father has the tools to remove the screws, but id like more input in whos running without them.
thanks for all the input so far!
Banned
Yes, they should be fine to leave them out. They wont cause any damage or uneven pad ware,ect.... They use the screws at the assembly plant to hold the rotors on while the rest of the car is being assembled. The screws provide no performance gain, or loss if they are removed.
Re: (yoffer)
yes they will prob. be fine if they are left out. To me honda put them there for a reason so use them. I dunno just imho think it's ghetto for not doing the job right then having to drill the heads off. also when your wheels are off your rotors will be kinda dangling there.
Re: (Kista20)
I work as a Honda tech, so you can trust me when I say they are NOT NEEDED IF YOU AREN'T ABLE TO REUSE THEM.
Your wheels are torqued anywhere from 60-80 ft. lbs, two little puny screws aren't gonna make your rotors fly off your car. They are installed on the assembly line for the workers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">also when your wheels are off your rotors will be kinda dangling there.</TD></TR></TABLE>
You do realize that there are things called brake calipers holding your rotors onto the hub, they will not be 'dangling' anywhere.
Re: (Skunk.Werks)
you had me at "Honda-Tech".... Im just kidding. That completely makes sense. i appreciate the input. This greatly expedites my break process.
thanks!
P.S. a little late in the game, but if anyone has tips for getting those damn caliper bolts, id appreciate that. I wrestled with this freaking things for EVER a while back.
THANKS!!!!
thanks!
THANKS!!!!
if you are using a racing jack or another air jack, use the arm that comes with it as a cheater pipe. put the socket on the bolt, slide the pipe over the wratchet handle and pull. never fails..
Re: (Convert)
if you cant get them out and there stripper get a punch with a decent point on it and take a decent size hammer and just go in circles until it breaks loose them take em out by hand when there loose enough, i had to do it on my hatch and i think thats better then just drilling the head off the screw
Re:
For anyone else needing to remove the same screws, try an impact screwdriver. It's not a pneumatic tool but rather a mechanical one. Hammer the end and the other end is spring loaded to not only push down to avoid stripping the screw but also twists at the same time. They're like $10-15 or so at a hardware store.
Re: Re: (Blk00EJ8)
check my first post above ^^^ I just don't see anything wrong with doing jobs the correct way
here is an impact driver just like the one I have only for $9.99 at northern tool, it's reversible so you can tighten and loosen by the impact.
http://www.northerntool.com/we...36882
the torch kit $19.97 at lowes but I'm sure you can get cheaper elsewhere like walmart or target.
http://www.lowes.com/lowes/lkn...=none
Re: Re: (Kista20)
those are just placement screws. They dont need to be on. You calipers will hold your rotors in place. Alot of aftermarket rotors, wont even have that screw for you.
crx18c1
17
04-09-2007 04:02 AM
rus
11
06-05-2006 12:01 PM
