Screwed up my car...
Old 12-23-2003, 06:42 PM
LazYRaCeR's Avatar
Default Screwed up my car...
Alright, just got home from work, PLEASE help if you have any idea
long story short, I was on the highway and over my music I heard a loud pinging, but it wasnt like detonation, it was like metal hitting ****... so I had to make it home so I kept going, the car did one violent jerk, and i just kept going... second violent jerk (all the while that metal hitting sound is going) the whole car shuts down, and I roll into my parking spot (thank god)...
open the hood, there is no smoke, the belt on the cam gears doesnt look torn, I have oil, and all liquids are good...
its to dark to check anything right now, but can someone please explain WTF just happened?
thanks...
Old 12-23-2003, 06:43 PM
ng
ng's Avatar
Well someone else on here had their mounts break. Take a flashlight and look under your car to see if anything is hitting.
D50boy's Avatar
Default Re: Screwed up my car... (LazYRaCeR)
blown motor. look around and you'll probably have holes here and there.
Old 12-23-2003, 06:44 PM
JDM-97CX's Avatar
i had a similar problem and it ended up bein rod knock. does your car seem slower??
JDM-97CX's Avatar
Default Re: Screwed up my car... (D50boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D50boy &raquo;</TD></TR><TR><TD CLASS="quote">blown motor</TD></TR></TABLE>
If the motor was blown it wouldnt exactly drive at all would it?? Dont give mis information, give real advice or none at all.
Old 12-23-2003, 06:45 PM
ng
ng's Avatar
He said it didn't drive at all, JDM. He said it broke down and he "rolled into his space." Read?
Old 12-24-2003, 09:11 AM
LazYRaCeR's Avatar
Default Re: (ng)
Ya, my car seemed slower, so you guys are saying that generally my car is screwed?
I am going to check to see if I can see any "holes", does this require pulling the head? or valve cover? or can I just look around from the top and see something?
Old 12-24-2003, 09:33 AM
WangChung's Avatar
Default Re: (LazYRaCeR)
take a flashlight and look all around ur block and mounts. look for gaping holes in the block or broken mounts. also, puddles of fluids.
Old 12-24-2003, 09:53 AM
Grimm's Avatar
Default Re: (WangChung)
may have blown a bearing or something as well. Had "similar" not exactly the same thing happen when I blew a bearing. (no violent thrusting but definatly some wierd bursts) and it just puttered out. Trying to re-start it afterwards made some loud screeching noises and hard chunking noises? Hope it helps..
Old 12-25-2003, 11:17 AM
LazYRaCeR's Avatar
Default Re: (Grimm)
Finally got the ***** to try to start it, and when I did, it actually started, and idled, but there was that LOUD *** metal pinging coming from inside the block, and I just turned it off. So you guys are saying whatever the damage is, it will probably require pulling the motor, and disassembling the block? if this is the case, then that BLOWS....
Old 12-25-2003, 12:20 PM
Global Moderator
Jimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LazYRaCeR &raquo;</TD></TR><TR><TD CLASS="quote">Finally got the ***** to try to start it, and when I did, it actually started, and idled, but there was that LOUD *** metal pinging coming from inside the block, and I just turned it off. So you guys are saying whatever the damage is, it will probably require pulling the motor, and disassembling the block? if this is the case, then that BLOWS....</TD></TR></TABLE>
Possibly but something had to of brought this on..were you low on oil?
low on coolant anything?? Let us know
Old 12-25-2003, 12:28 PM
HATCHingMN's Avatar
Default Re: (USDMDC2)
ah.. a minor heartattack!! save money for new motor transplant!!
Old 12-25-2003, 12:30 PM
EJ1_519
Guest
Posts: n/a
Default Re: Screwed up my car... (JDM-97CX)
I doubt that this is a blown motor
Modified by EJ1_519 at 1:41 PM 12/25/2003
Old 12-25-2003, 12:34 PM
uNbrokeN's Avatar
same thing happend to my friends b18 CRX
it was hes valve,
Old 12-25-2003, 12:49 PM
-auSTIn-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX &raquo;</TD></TR><TR><TD CLASS="quote">i had a similar problem and it ended up bein rod knock. does your car seem slower??</TD></TR></TABLE>
It might be a rod. My bro had the same sort of symptoms with his car, had it checked out and the mechanic told him it was just his plugs, switched em out and the next day threw a rod through his engine...I deff. wouldnt drive your car and try and have it checked out ASAP, it could save your motor....
loki2323
05-05-2015 12:50 PM
AntMan401
08-09-2008 09:44 AM
EF_9
Southern California
25
07-30-2008 10:24 PM
illagee
05-03-2006 10:13 PM
Quick Reply: Screwed up my car...
