school me on cam specs
i have the oportunity to get a cam made up regardless of stage/ spec NA or boost for 250 plus 100 dollar core charge my question is what is the stock SOHC specs and what recomendations do you guys have on which specs/ stage i should get for my SOHC ZC vtec?
Re: school me on cam specs (Crx_Civic)
well i figure I want the vtec lobes agressive and the non vtec lobes mild i can tune my valve lash to get top end, out of the hole, or all around performance, so basically im asking for someone like myself that does know how to manipulate my valve lash what would be the best specs for tuneability (-is that a word?) ??
Re: school me on cam specs (duefuss)
Well your lash adjusters aren't meant to be constantly adjusted. Sooner or later they're going to get worn out. Unless you have a 600hp drag car, messing with your lash won't do much for significant performance gains anyway. If you want to play with your "tune", get forced induction and a boost controller. You'll have more top end and out of the hole with FI than without. Shoot for real HP, not placebo HP.
Re: school me on cam specs (King V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jahdamanga »</TD></TR><TR><TD CLASS="quote">the SOHC ZC non-VTEC is identical to the D16A6 except for the cam</TD></TR></TABLE> i have SOHC-VTEC and im not lookin for replacement parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King V »</TD></TR><TR><TD CLASS="quote">Well your lash adjusters aren't meant to be constantly adjusted. Sooner or later they're going to get worn out. Unless you have a 600hp drag car, messing with your lash won't do much for significant performance gains anyway. If you want to play with your "tune", get forced induction and a boost controller. You'll have more top end and out of the hole with FI than without. Shoot for real HP, not placebo HP.</TD></TR></TABLE>
yes they will wear out they were designed that way. and yes you can tune for top end out of the hole and all around get up and it does make a difference at all levels of horsepower. do you think tuned N/A cars run the manufactured bracket on lash specs? dont think so. and its pretty obvios turbos make HP but i didnt ask for input on how to build my car.. just some numbers/input on cams from someone who knows what theyre talking about. nice try thanks
Seems like a big waste of time adjusting your lash for performance. To me it screams "I want it to sound like I know what I'm doing". Unless your stuck running a completely stock engine, why?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duefuss »</TD></TR><TR><TD CLASS="quote"> do you think tuned N/A cars run the manufactured bracket on lash specs? </TD></TR></TABLE>
No, they run whatever lash specs the cam manufacturer recommends. Or in your case, whatever you want "for better out of the hole or top end". Anyway, enjoy wasting your time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King V »</TD></TR><TR><TD CLASS="quote"> Shoot for real HP, not placebo HP.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King V »</TD></TR><TR><TD CLASS="quote">Seems like a big waste of time adjusting your lash for performance. To me it screams "I want it to sound like I know what I'm doing". Unless your stuck running a completely stock engine, why?
if thats what you think then fine leave it be thnx for the input.
BauleyCivic
08-01-2004 12:23 AM
TheShocker
12-16-2001 10:01 PM
