Is it safe to run the p30 on my car?
Old 08-11-2003, 08:09 PM
DailyBlown's Avatar
Default Is it safe to run the p30 on my car?
I just bought a skunk2 chipped p30 ecu from my friend and i have jdm b16a sir2...I was wondering if it is safe to run this on my car... i know they are both obd 1 and it plugged right in no problem....but i am afriad i might blow my motor....thanks
Old 08-11-2003, 08:11 PM
FifthGearOnline's Avatar
we need to know what engine you have
Old 08-11-2003, 08:19 PM
DailyBlown's Avatar
Default Re: (FifthGearOnline)
I have the B16A SiR 2...it is not built...I was wondering if I can use it and just not shift at high rpms
Old 08-11-2003, 08:31 PM
nwdave's Avatar
Default Re: (import92c)
If you have a P30 from a '94-'95 del Sol VTEC then it will work fine.
Here ya go:
http://www.hondata.com/ecus.html
Old 08-11-2003, 08:40 PM
DailyBlown's Avatar
Default Re: (delsolguy)
I believe it is from a jdm b18c
Old 08-11-2003, 11:41 PM
ill phil's Avatar
I do believe the p30 only came with b16 engines. As long as its OBD-1 and you don't over rev you can run it. B18c comes with a P72 ECU.
Old 08-11-2003, 11:52 PM
nwdave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by import92c &raquo;</TD></TR><TR><TD CLASS="quote">I believe it is from a jdm b18c</TD></TR></TABLE>
It wouldn't be because only the P72 is set up to run that style of IM.
Old 08-12-2003, 12:28 AM
Banned
d0nkeyxPunch's Avatar
Your car will prolly run rich and get bad gas mileage because of the Skunk2 chip that you have on your P30. Thats about it, but it won't blow up your engine.
Old 08-12-2003, 12:47 AM
Banned
blykins's Avatar
Default Re: Is it safe to run the p30 on my car? (import92c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by import92c &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if it is safe to run this on my car... i know they are both obd 1 and it plugged right in no problem....but i am afriad i might blow my motor....thanks</TD></TR></TABLE>
An ECU isnt going to blow up your engine unless the ecu's rev limit is more than the motor(ITR ecu on an LS)
Old 08-12-2003, 05:08 AM
DailyBlown's Avatar
Default Re: (EM1b18cR)
Yeh I have already noticed the gas milage difference after a few days
Dool_Ohver_Hed_Cam
10-02-2007 08:46 AM
project_delta
06-11-2006 02:13 PM
EG6-SiR
04-27-2003 10:19 PM
degooser
35
03-26-2003 09:58 AM
-CP-
09-30-2002 09:02 AM
Quick Reply: Is it safe to run the p30 on my car?
