safc help
Re: safc help (RidinlowHatch)
Did you initialize all your settings and start from scratch?
When I installed mine, I initialized it, then reset the settings.
In the settings mode on the screen where you choose the car and cylinder #, you have to hold the pedal to the floor for 10 seconds so it can learn your throttle position.
It's in the manual, see their web site for the pdf.
If you have already done this... I don't know what the problem would be. Maybe initialize it again and see if you still have a problem.
possibly your throttle cable is not very tight causing the engine to no be able to go to 100% throttle. but im not sure. your best bet probably is to do what koreonwilcox said. but just my input.
Re: (H22BuiltEGhatch)
hi ya guy have apexi safc2 in civic ek v-tec but every time i connect the pressure sensor the engine management light comes on after a few second of starting , anyone got any ideas have sensor set to pressure but there is an in and out setting i am not sure about . an in /n.ireland these controllers not heard of much here so bit stumped any help would be great
Nameless Warrior
02-01-2007 08:58 AM
