Are S2000 sidemarkers the same as EK sidemarkers?
Like the topic says....I just need to know because my friend put some clear ones on his S2000 and he's giving me his sidemarkers for my EK. Thanks guys
Also, does anyone have a good template to print out? I searched and found some info but no template for an EK, just an EG.
Re: Are S2000 sidemarkers the same as EK sidemarkers? (JDMjdawg)
negative, they are not the same...
<FONT COLOR="red"><FONT SIZE="8">EK9 Markers</FONT></FONT>
<FONT COLOR="blue"><FONT SIZE="8">AP1 Markers</FONT></FONT>
However you have to cut into your fender and splice wires anyhow, so theres no reason you cant mod the s2000 markers to fit your EK.
Re: Are S2000 sidemarkers the same as EK sidemarkers? (DxHatchback)
Hmm....I don't know about that man. Thanks, but I'd rather do what I think would look best on my car and what I like
Re: Are S2000 sidemarkers the same as EK sidemarkers? (blackEyEdpEas)
the ek sidemarkers do look alot better then the s2k, and as soon as i decide that i no longer want to be lazy i will install my ek sidemarkers.
Re: Are S2000 sidemarkers the same as EK sidemarkers? (gambit33)
yeah they do, if you don't ever get around to installing them hook a so cal ek brother up!
I got mine at a shop in torrance ca called jdmpro. They are oem honda still in the honda package. Part number 34300-SL4-003, and 34350-SL4-003 I think i paid like 35-40. I have had them sitting in my glove box for about 3 month now hahaha
does anyone have any pictures of the process? how much do you have to cut off the fender?
i did my side markers myself. one tip for u do it yourselfers.
TAKE YOUR TIME!
get a ruler, marking utensil, anything u can, just take your time. make sure they are palced right on both sides, lined up, etc.
since u gotta drill into your car, u kno you dont wanna mess this one up
good luck!
TAKE YOUR TIME!
good luck!
Re: (stripes777)
make a template so you can se where they will be and you can tape it to the car while you cut and make sure both sides are even, measure that **** like 40 times before you even begin to cut.
S2000 and DA Integras used the same sidemarkers.
DC and EG Civics used the same sidemarkers.
EK is just out there all by itself in terms of the sidemarkers.
One important tip: USE a sheet metal nibbler found at radioshack. 10 bux. Makes the job really easy and clean. Here's a pic of the correct measurement on my car when I did it.-The middle of the sidemarker has to be on the dot:
