S2000 head on a 02 SI?
I was reading the letter's in the most recent issue of honda tuner, and they said an s2000 head would fit on a K20 engine. Well, first question, is this true, has anyone attempted it yet. And if i was to do this, any idea on power gains, if any? i own a 02 civic hatch Si. thanx for any help... o and one more question, does anyone here visit ClubSi.com, and if so, are you having trouble going to the site, it doesnt seem to be there anymore? thanks again...
Re: S2000 head on a 02 SI? (SilverCivic2k)
Just because they spin the same way doesn't mean everything is going to be compatible. Answers with a little more insight behind them are definitely helpful!
Re: S2000 head on a 02 SI? (Blazex12)
F20C is 87mm, K20 is 86mm, not 100% sure if that is a problem for compression though.
[Modified by RR98DX, 12:54 AM 6/24/2002]
Re: S2000 head on a 02 SI? (DxHatchback)
Well, i bought it the first day it came out, i have about 5,000 miles on it, so it is broken in, and im not ready to mess with it yet, i mean what are the chances i'll find an s2000 head anyway?? just good for later, when im ready to upgrade performance, fisrt thing is i want to lower it, get rims, and the type R body kit.
Re: S2000 head on a 02 SI? (dj@wedreamz.net)
i,v not done it but it will work i dont think you get to much power but you car take it up to 9gsssss.
New User
Re: S2000 head on a 02 SI? (Civicboy)
I have an F20C head for sale if you want to try it out.
It needs one valve, and some headwork. ~ 600 dollars in work.
PM me if you are interested.
is there any ready kit to connect the s2000 trans to k motors or even others if possible, also is there any other stuff to be used to fix those front wheel engins vertically in the car
the S2000 head will not bolt to the k series block. Its a completely different design. The S2k uses an idle gear to turn the cams via a chain that runs off the crank, where as the K series uses a chain to drive the cams.
