S2000 Ballast, Install .. How??
Hey Guys,
I've searched and looked over the 25 page HID thread and I still can't find any answers. I've purchased S2000 Ballasts and HID's and want to know how do I hook them up to the stock headlights. I know I will lose my high beams (00 Civic - dual filament bulb). I had S2000 projectors coming next week, so im preparation to do the retro fit I'm concentrating on wiring it up. See pictures below .. http://198.38.12.245/~fred/s2000_hid1.jpg http://198.38.12.245/~fred/s2000_hid2.jpg <U>Questions</U> 1. The Ballast has 3 connections, 1 is for the HID bulb, the other plastic clip I'm assuming is a power/ground and the other one - I got no idea? 2. The stock headlight plug is a 3 tooth connector, I don't know if the sell some kind of wiring kit so I can connect it to the ballast? 3. Do I have to wire in some inline fuse (20A)? 4. Do most people cut into the existing headlight wires? Any help is greatly appreciated, thanks. |
Re: S2000 Ballast, Install .. How?? (FredoSP)
your stock headlight bulb is 3 wire
ground/low/high use the ground and low wire it up to a relay, have the relay pull power straight off the battery that way your not pulling so much power from the stock wiring harness also I put an inline fuse for each ballast, that way if one fuse blows i should still have one headlight working im guessing for the ballast, black is ground, and white is power |
Re: S2000 Ballast, Install .. How?? (Dan GSR)
Dan,
Any pics of the wiring? If not i'll call brian and we'll meet up one night and I can see them in person. |
ttt
Re: S2000 Ballast, Install .. How?? (vtec69)
I just hooked up an 02 Acura RL HID kit straight up to my stock harness. Have had no problems yet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP »</TD></TR><TR><TD CLASS="quote">meet up one night and I can see them in person.</TD></TR></TABLE>
sure, we could prob do that |
im not sure on the wiring since all ive ever dealt with were philips ballasts with the simple power/ground wires.. but im sure it wont be hard to figure out.. im actually doing a retro this weekend on my dads 02 tacoma, we're putting in 2003 Lexus RX330 projectors.. and shortly after, i will be retroing a set of s2k projectors on my STi.. if you can get another set of s2000 projectors, let me know.. even though i have a set already, i will buy any set of s2k's i can get my hands on
Re: S2000 Ballast, Install .. How?? (MTK Kommander)
bump for some info, i would guess power/lo to WHT ground to black and the third wire looks like a ground
Re: S2000 Ballast, Install .. How?? (JDM R)
check out HIDPLANET.com....they might be able to help u
MTK - You got a PM, thanks guys, Ill keep everyone posted.
