S20 gearbox......which lsd?
Hi there,
I have a jdm 1992 delsol with a d15b and a non-lsd S20. What would you guys recomend for converting it to LSD. I am looking for a cheap option, preferably an upgrade kit. Does phantom grip or kaaz do LSD for this box???? I need your advice....
P.S I don't know if it makes a difference but i'm planning on turboing my d15b and putting out about 200whp.
Cheers Greg
Cheers Greg
Re: S20 gearbox......which lsd? (NZDelsoldude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NZDelsoldude »</TD></TR><TR><TD CLASS="quote">Hi there,
Cheers Greg</TD></TR></TABLE>
LSD is great addition to any FWD car. definatly aids the handling and allows you to put the power into the road. cheap upgrade would be to locate the JDM LSD tranny and swap that in. phantom grip is not a LSD is just a addition which binds the spider gears together.
Kaaz is big improvment over the stock open diff and even stock gear LSD, as it is a clutch type, which can be setup into a different lock ups from 1 to 1.5 to 2 way diff and will certinly put the power to the ground, it will also not break very as stock diffs can and will work for drag and track. price and that it needs to be rebuilt every few seasons are its downsides. but otherwise
