Running rich black smoke.
I threw a code 43 suel system supply on my 93 cx hatch. I checked the voltage on the o2 and it was dead so I replaced it. The car runs better now and the cel went out, but when I start in first gear from a stop a fair ammount of black smoke comes out. It only happens in first gear and not once the car is underway. I know black smoke means running rich but why would it only happen in first after I fixed the o2?
Modified by GSX TO CX at 2:02 AM 4/22/2005
Re: Running rich black smoke. (GSX TO CX)
pull your plugs and take a look, your cat might also be shot, but if the 02 sensor was dead and you pulled it what did it look like? also check your fuel pressure regulator or at least fuel pressure make sure you are getting the right amount, possible bad seals on your injectors??? lots of options.
Have you considered installing a catalytic converter if you are concerned about the smog coming out?
Is your timing ok?
Did you seafoam it already?
Is your timing ok?
Re: Running rich black smoke. (f1z1c)
The timing is good. I don't want a cat, but that isn't the problem because I haven't had a cat in a while and it just started smoking a while ago. The way I figure is by averaging 38mpg compared to 12mpg for an suv I'm really not polluting that much. Plus MN has no emmisions testing.
