running problems?d series engine swap.
hey lads,just finished putting d16z6 motor into my sedan.it originally had jdm d15b,and im still using that ecu and wiring loom.engine seems to idle a bit low now and hesitates on acceleration,do i need ecu to match engine or should it be ok?
i know d15b produces similar power at similar rpm but im not sure if its fueled enough for 16z6.
Make sure you get the P28 ecu to run it.
Thats probably why it hesitates, D15 has a diff map than the d16 requires for optimal factory spec performance.
Re: (Ron454321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ron454321 »</TD></TR><TR><TD CLASS="quote">No need to get it chipped, the P28 is for the Z6</TD></TR></TABLE>
X2,
Are you getting any Check engine lights now that it is running?
If so what ones?
X2,
If so what ones?
Re: (97Ej6mike)
no .no faults or check light coming on.i completley rebuilt the engine i put in also maybe it needs more running in,before it will run just right.
Untamed_Hatred
01-29-2008 05:02 PM
scarface50370
10
01-23-2006 04:13 PM
Carolina Fried Rice
14
03-02-2005 10:23 PM
